k0ua
Epic Contributor
I would use my bandsaw to try to make an accurate square cut as possible. But whatever method allows you to make a square cut should work.
If you want a double barrel with a 16"-20" inch barrel than I'd recommend buying a coach gun or a cheap double barrel and cutting it down.
In my opinion, never settle for what you can afford today when it's not what you really want. When buying high end items, it is always better to wait for the right deal to come along, and buy only what will hold or increase it's value. With double barrel shotguns, either side by side, or over and under, if you buy quality, it will never decline in value. If you buy cheap, it will always be cheap and your results will reflect that.
For clay pigeons, you really need to stick with over and under shotguns.
External hammers???? Why? I can see no advantage for that. If you find one, if will be very old (or a replica) and probably unsafe to fire modern ammo.Where can I find a 20 gauge side by side with external hammers and 26-28 inch barrel? I don't like the coach shot guns, barrels to short which is Ok if I was gonna ride a stage coach guarding the pay-role to the Ponderosa for Ben Cartwright.
Eddie is right on the money, buy the best or what you truly want and you'll never be disappointed.....
gunbtoker.
