3 point log splitter
   / 3 point log splitter #11
It WILL work, but you will fall asleep waiting on the ram! lol
SR
   / 3 point log splitter #12
When I remove the backhoe to put on the splitter, I use the rear remotes. The next time I split I will try the backhoe connections. As far as speed goes....I never have to wait with the Split Fire as it splits both ways. (Don't have to wait for the blade to return)
   / 3 point log splitter #13
How do you like it... would you buy it again if you had it to do over?
Considering one for the L3800
   / 3 point log splitter #14
I love my split fire also. I agree I'm never waiting on the spliter. how long have you had yours?
It takes 3 people to ensure little to no downtime. One to supply wood to the lift or table, one operate / manipulate the wood and splitter, one to clear and stack or bag the wood. With 2 people the splitter is idle probably 30% - 40% of the time especially splitting ash as it only takes about 4" of stroke most of the time. I found it takes ~ 10 minutes additional time to split and stack per 1/3 cord simultaneously as opposed to splitting into a pile. to stack from a pile to 1/3 cord takes me about 20-30 minutes depending on how far I have to move the wood.
I run my tractor at 1800-2000 rpm when spliting with 2 people it's plenty fast. although I believe my tractors max flow is 17.1 GPM at ~2700 rpm
   / 3 point log splitter #15
get the 4 way, and log lift it's an awesome table. you can easily fit 16" pieces next to one another on the table. if you cut to longer that 16" consider one of the larger lengths. the 24" is like 32.5-33" between the uprights so you can just barely fit 2 16" pieces on the splitter at the same time. If I could do it again I would go with a 28" model.
   / 3 point log splitter #16
that's a tremendous flow difference over the OP's and most people who post with the same question.
   / 3 point log splitter #17
I really like the splitter and have had it for two years...no regrets at all. Canadian made so with our dollar in the tank, chances are it would be a bargain for Americans.
   / 3 point log splitter #18
I sent an e-mail for more information...
This way my splitter can stay home and my brother will have the 3 point he wanted all along.
His Lopi stove is small... it works terrific... just have to be careful not to cut too big or wood won't fit.
They were thinking getting rid of it when they bought the home... insurance had all kinds of questions and was OK when the seller had a permit for it...
They also have all the oak anyone could want... so the family room is now the most popular place in the home every night... doesn't take much to really warm things up.
Can the 3 point be lowered to the ground to avoid extra lifting?
Mine works just fine off the tractors hydros
Sent from my iPhone using TractorByNet
   / 3 point log splitter #20
Yes the 3pt can be lowered. but for $500 the log lift was more than worth it since it doubles as a table.
check out the video below
https://youtu.be/ZEdMFiQxvk0
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2015 Dodge Charger Sedan (A50324)
2015 Dodge Charger...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A52748)
2000 John Deere...
Horst Quick Tach Bucket (A52349)
Horst Quick Tach...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
