Shop Smith
   / Shop Smith #21
Hey, never have enough tools!
Have 2 bench saws.
A Makita 8" portable for quick job site cuts that simply won't die.
A 10 cast iron beast with a Bessemyer rip fence as well as a custom sled.
When I set it up I used my micronometer and vernier calipers as I wanted precision, and got it.
With the beast I can slice 1/8" X 3" slats to make storage bins as well as rip 2" oak all day long.
Also have a 12" Makita sliding miter saw for fine angle work like picture frames and Ogee mouldings.
But then I am a 'tool nut'.
Each tool has its job.
   / Shop Smith #22
Yesterday, i saw one of these at the "Restore Center". Restore Center is part of Habitat for Humanity and people donate tools and materials. I'd never heard of one before reading here in the forum. It looked to be pretty old, heavy and solid built. Lots of parts were piled up with it so i guess most everything was with it. They were asking $150 for it. I have all those tools but the lathe. I'll be interested to see how long before it sells or is disposed of.
   / Shop Smith #23
Thing is, lots of us are in between those two!
And, it's a PITA to want to use the band saw to make "a" cut one day, then use the table saw for a cut the next day... It's just too much time monkeying around to do a set up for one cut... OR having to go back to a tool, because you forgot to do a cut on what ever you are making.
AT LEAST that's where I find myself...
SR
Exactly... I am one of those between the two. I surely would cursing up a storm if I had to go back and forth between setups for every other cut. I can't imagine trying to plan out all of your cutting ahead of time for efficiency. Space though is my problem so many of my tools are on casters. My poor truck sits outside all of the time. The wife's car sits out a lot when projects are underway. Just did clean up and made room for her car in this cold weather. Need a BIGGER shop! On my to do list this year.
   / Shop Smith #24
^^^Amen
I think a key to marital bliss is an attached garage with only two cars and nothing else AND a separate shop at least 100 paces away... close but not too close.
I found in Washington it was never a problem... if something was in the way or taking up room or after the holidays... it was a simple few steps to take it to the shop loft and problem solved.
Right now I have a Stihl saw on the kitchen table in Oakland... just no room when everything is under one roof...
Try as hard as I can... an open workbench is just an invitation to pile on...
The nice thing about having a separate shop is I can leave a project and come back days later and it is EXACTLY how I left it... no chance of that in Oakland...
   / Shop Smith #25
^^^Amen
I built my wife's "dream home" on 2 acres in the woods. Had the money to locate a 56x30 shop (40x30 infloor radiant heat) about 100' away. Due to a design flaw, I forgot to put any windows on the house side. I ran water and electric (should have run cable). One of these days I'll install a hot water heater and dig the hole for waste water (right now it only empties into a bucket so I have to be careful...figure a 55gal drum with holes should work in this sand/gravel acreage). As for "personal" requirements, #1 no issue (we are in the woods). Once and awhile though I have to do that "turkey trot" thing...thinking about a porta potty.
   / Shop Smith #26
...... As for "personal" requirements, #1 no issue (we are in the woods). Once and awhile though I have to do that "turkey trot" thing...thinking about a porta potty.
Or build an outhouse. :)
   / Shop Smith #27
As I was posting this, I just looked again at the thread title and realized how much this on has diverted!! LOL!
Back to ShopSmith... They've been headquartered in Dayton for as long as I can remember. They used to be a pretty prominent local company but not so much any more. I don't even know if they still have their "factory showroom" any more or if they even still build or develop anything here locally. Years ago, I worked for one of the "Big-6" CPA firms and ShopSmith was a client. One of my coworker's dad worked there doing machining/R&D work. He told me that his dad had made an ice cream maker using his ShopSmith power head. He used a soft nail as a shearpin to let him know when the ice cream was ready!! I can also remember going to the mall (both here in Dayton and elsewhere) and seeing a ShopSmith salesperson doing demos on how easy it was to go between the tool change overs. Of course, I don't remember him checking if things were square after doing these changeovers!
I've been watching CL on and off for a while to see about getting one. Like many others, I don't have the need (or the room) for a full shop but wouldn't mind having the ability to have the various tools handy, even realizing that the setup is a compromise. I also have a Gravely walk-behind tractor. I often tell people that a Gravely is like the "ShopSmith of Tractors" - it can do just about anything but does require changing from attachment to attachment. In all honesty though, that's enough of a pain that I'm considering buying a second one so I can keep one of them always attached to my mower and then switch between the attachments on the other one. I wonder if I bought a ShopSmith if I'd just end up reselling it later?
   / Shop Smith #28
Thinking of getting a Mark V,anyone have experience with them? Thanks,Tim
I have also owned a SS for some 20 years. It had been sitting in a storage building since brand new, mostly in water or in damp conditions, but it was free. I had to completely restore it before being able to use any of the accessories, but it was a fun learning experience. Just be aware, new and used parts, although available, are very expensive. Check their forum at Shopsmith Forums -- Sharing Information About Woodwoking and Shopsmith Tools and I think you may want to rethink taking one for even free.
They take up a good bit of floor space, takes a lot of time to switch from one feature to another, severally lacking in accuracy, dangerously small tables, and lack most of the now-standard safety features. Nonetheless, I would have never been able to get into woodworking without having gotten one. Even though they're called All-In-One machines, you'll get real tired of switching from one function to another, especially when you forgot to make just one small cut, or whatever.
Mine's still in great operating condition. But I'm replacing each function as fast as I can afford with stand-alone equipment. If you're short on funds, short on space, have a lot of patience and want to get 'started' in woodworking, snag one. It's a good learning experience.
   / Shop Smith #29
I have also owned a SS for some 20 years. It had been sitting in a storage building since brand new, mostly in water or in damp conditions, but it was free. I had to completely restore it before being able to use any of the accessories, but it was a fun learning experience. Just be aware, new and used parts, although available, are very expensive. Check their forum at Shopsmith Forums -- Sharing Information About Woodwoking and Shopsmith Tools and I think you may want to rethink taking one for even free. They take up a good bit of floor space, takes a lot of time to switch from one feature to another, severally lacking in accuracy, dangerously small tables, and lack most of the now-standard safety features. Nonetheless, I would have never been able to get into woodworking without having gotten one. Even though they're called All-In-One machines, you'll get real tired of switching from one function to another, especially when you forgot to make just one small cut, or whatever. Mine's still in great operating condition. But I'm replacing each function as fast as I can afford with stand-alone equipment. If you're short on funds, short on space, have a lot of patience and want to get 'started' in woodworking, snag one. It's a good learning experience.
I would say this advice is spot on!
Sent from my iPad using TractorByNet
   / Shop Smith #30
AND THEN, what really killed Shop Smith, was when the Chinese copied it and came on the market for a fraction of the price of a new SS!
SR
2015 Peterbilt National NBT40 40 Ton Straight Boom Crane Truck (A60460)
2015 Peterbilt...
More info coming soon! (A56858)
More info coming...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
2001 CATERPILLAR CB-634C SMOOTH DBL DRUM ROLLER (A60429)
2001 CATERPILLAR...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
