Looking for a decent generator.. 5000 watts
   / Looking for a decent generator.. 5000 watts #1
BrianDT
I am looking for a good quality generator that will be close to 5,000 watts. I need it to run a refrigerator, open garage doors and maybe run a few tools if needed. This would not be to run a full home! Just our cabin that is pretty rustic.
I need one that will work when needed and will put out clean power as we have sensitive devices that we use once and a while and power is only working out there 75% of the time.
I am looking at this Subaru.... but question if it is better than others.... Here is the only review I can find on it.
   / Looking for a decent generator.. 5000 watts #2
How do you figure you need 5000W?
Motors do need a lot of power to start, and any kind of heater will take gobs of power.
But, if you don't run a lot of things at the same time, and you don't have any big motors,
you may be happier with something smaller.
I have a 5000W (6250) and I hate it. Noisy and thirsty. It is a flathead Generac, and it IS
much noisier than any OHV unit. I need 2000W to start my reefer, but it only needs 100W when
running. Something like a table saw will take more, but I don't use them in an outage.
So I am going to get a 2000W inverter genset, like the Honda EU2000, or the equivalent from
Yam or Kaw. I might even try one of the Chinese 2000W units, like the Ryobi or Coleman.
   / Looking for a decent generator.. 5000 watts #3
Look at Honda 3000iS. Very very quiet. Electric start. Has Eco throttle mode so very conservative on fuel. Plenty of power for my occasional power outage needs and somewhat portable. A bit spendy though.
   / Looking for a decent generator.. 5000 watts #4
Depending on what kind of power tools you have in mind you won't need 5,000 watts. Also electric heat will take loads of power. I would look at a 3000 watt Honda or piggy backing 2 2000 watt Hondas. Picky backing them is cheaper and provides more power.
   / Looking for a decent generator.. 5000 watts #5
Not really cheaper for the two about the same I think ($2000) but you do get some more wattage. The 3000 is quieter than a 2000 and you have one machine vs. two to maintain... the two reasons I went with the 3000. One advantage going the 2 by 2K route is you can grab one of them and take with you much easier (weight) than a 3000.
   / Looking for a decent generator.. 5000 watts #6
Only if being portable isn't important to you. They make another 3,000 watt that weighs only 73 pounds vs 130 pounds, but it cost $2,500. I already have a whole house generator, so my little 2,000 watt generator must be easily portable.
   / Looking for a decent generator.. 5000 watts #7
Maybe the OP has a well pump and needs the 5kw. Sorry I haven't had personal experience except my 10kw diesel homemade.
   / Looking for a decent generator.. 5000 watts #8
Honda EU6500IS. Quiet, efficient, electric start, uses the starting battery for the surge off of idle mode. Remote control start option. You get what you pay for.
   / Looking for a decent generator.. 5000 watts #9
FWIW, my daughter works for a large equipment rental company. Their Subaru generators apparently hold up well. I would have bought one a few years ago, but I thought the price was a bit high for my application.
   / Looking for a decent generator.. 5000 watts #10
OP - How important is $$?
The one you are looking at seems to run about $1K
This is a $2K up solution, and if he REALLY needs 5KW at one time he'd need two of the 3KW for about 4 grand.
I had a small Robin/Subaru and it was great, until one of my son's "borrowed" it.
OP - Your choice looks good if you really need 5KW
Unused 2025 CFG Industrial MH12R Mini Excavator (A59228)
Unused 2025 CFG...
207272 (A52708)
207272 (A52708)
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
17102 (A56859)
17102 (A56859)
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
