Looking for a decent generator.. 5000 watts
   / Looking for a decent generator.. 5000 watts #11
If you keep your eye out there are good used generators on the market through CL. I picked up a 6000watt liquid cooled Honda that makes no more noise than an idling Accord when someone upgraded to a permanent automatic LP generator. Also, many people sell generators because they need the carburetor cleaned which takes about half an hour. If you need something right away and are on a budget, the HF Predator generators are good deals. Not necessarily the very best or quietest generators on the planet but the price is hard to beat (and they do work fine). Subaru/Robin engines are great too. I'd personally stay clear of the high priced Yamaha/Honda inverter generators unless you are using it for an RV or camp.
   / Looking for a decent generator.. 5000 watts #12
Equipment rental operations can be a good resource:
1) You may be able to rent, or get a demo on, a unit you are interested in. Useful, unless you don't mind loud.
2) A good shop will keep up with maintenance, and many will turn their rental stock over fairly often. You may get a shot at buying a higher-end generator with a scratch or 2, at a reasonable price.
Others are paying a bit more attention in recent years, but Honda and Yamaha are two lines I'd also check out if I wanted quiet performance, w/o additional modifications. Inverter gens are neat to have in one package, but there are other options.....
A good quality UPS will clean up the power from most generators. If your grid power is bouncing around that much, you probably should run a UPS on your critical items regardless if a generator is used.
Just my :2cents: .....
Rgds, D.
   / Looking for a decent generator.. 5000 watts #13
I have two generators. The one that gets used most is a 1100/900 watt 2-cycle camp generator that is very quiet. It's not an inverter model, it's an interruptor model that just cuts the spark when voltage gets too high. It will run 4.5 hours on a gallon of mixed gas, and besides camp use it will run either the freezer, refrigerator or satellite TV, but only one at a time. :D I paid $149 at Coastal Farm about 15 years ago. Don't leave fuel in it.
My other generator is a 5000/4500 watt Harbor Freight cheapie that I paid $279 for in 1997. It will run the well pump, which is not very relevant since I have a 2500 gallon gravity feed cistern. It will also run the water heater, which is a real luxury. Even so, we can take a hot bath by heating a laundry tub of water on the wood stove and mixing it with cold water in the bathtub. The generator has a spark arrestor, not a muffler, and is so loud it will give you a headache if you are in 100' of it. I also used it for building an addition to the barn. Since 1997 it probably has about 70 or 80 hours on it. It will run about an hour on a gallon of gas (90 minutes on a 1.5 gallon tank). When I put it away I drain all the fuel, fog the cylinders, bag the intake and exhaust and store it in a dry barn. It will sit for a couple of years and still start fine. The only modification I have made is to weld an axle and handles to the roll cage and install wheels. I should install a muffler too, but have never got around to it.
   / Looking for a decent generator.. 5000 watts #14
   / Looking for a decent generator.. 5000 watts #16
For power with no concern about noise, Champion is a good as any. As others have stated the sound insulated Invertor generators .
   / Looking for a decent generator.. 5000 watts #17
Why not use a power surge protector for electronics?
   / Looking for a decent generator.. 5000 watts #19
I am looking for a good quality generator that will be close to 5,000 watts. I need it to run a refrigerator, open garage doors and maybe run a few tools if needed. This would not be to run a full home! Just our cabin that is pretty rustic.
I need one that will work when needed and will put out clean power as we have sensitive devices that we use once and a while and power is only working out there 75% of the time.
I am looking at this Subaru.... but question if it is better than others.... Here is the only review I can find on it.
Seriously, garage door openers can be released to work manually. Just pull the cord to release it from the drive track. Refrigerators, lights and a few tools don't use much.
As to sensitive electronics, get a UPS like this for less than $60.
Object moved
Then clean power won't be so critical and you can get a cheaper and smaller portable generator.
   / Looking for a decent generator.. 5000 watts #20
A garage door opener doesn't pull that much power. They usually are rated at 1/2 - 3/4 hp.
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
24220 (A56859)
24220 (A56859)
2023 CAN-AM HD7 RTV (A59823)
2023 CAN-AM HD7...
2018 Chevrolet Tahoe SUV (A59231)
2018 Chevrolet...
2018 Ford Explore AWD SUV (A59231)
2018 Ford Explore...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
