Universal choke/throttle cable sources?
   / Universal choke/throttle cable sources? #11
I try to avoid that store. Every time I go there I walk out with an empty wallet:mur:
That's why it's called the Shelby Mall.
   / Universal choke/throttle cable sources? #12
I once needed cables to remotely control my snow plow valves.
I bought the cables they use to actuate PTO pumps on dump trucks, the kind that takes power from the transmission.
They were very affordable, tough and rugged with about an .80 thou rigid inner that easily push/pulled the hydraulic valves.
Ran that old plow for about 8 years with no problems at all.
remember where you got them?
Never thought to try surplus center.
I think I'll have to give one of these a try 88" CONTROL CABLE
I think I'll order one. I think I can use the clevis end on the pump instead of the little side-stud thingy that the wire goes in, and I can get a threaded ball end to work on the lever end. I like that price too.
Thanks, I think the problem is solved for now...at least if I can make it work.
   / Universal choke/throttle cable sources? #17
Sure, at a local auto parts that catered to garages.
I'm in Canada so the name would not matter.
Suggest you try one that caters to trucking rather than a 'goodies type store'
   / Universal choke/throttle cable sources? #18
Anyone got any good places with a wide assortment of good throttle/choke cables?
Want to replace the OEM one on my ford 5500 backhoe. Seized up years ago and previous owner just actuated the lever by hand. I installed an old cable I had on the shelf, one of the push pull types and mounted it down by the steering column as it was way too short and had the wrong end to hook to the factory lever.
One end is just a blank end that hooks to the injector.
The end that connects to the lever has a short ~4" steel rod/guide. Since you cannot "push" a cable into a sleeve, this is kinda a guide.
Will see if I can get some pictures. running to the shop now to do so
TSC sells a pull cable that I have installed on 65+ fords ( a 5000 as well ) ). I think some of them actually say 'choke' but some don't.
They fit int he oem holes in my dashm and are PLENTY long to make it tot he IP. then just slip the core out. cut the sheath to fit, fi the end cap. slip the core in, attach, lock, trim.
   / Universal choke/throttle cable sources? #19
That's what I was going to suggest. TSC, O'Reilly, Napa, should all have something on the shelf. You can at least look at it and try to see if it'll work, which is hard to do with online purchases.
Problem is I need one without the "knob".
I currently have one of them types and drilled a hole to operate. The 5500 has a hand lever that needs an eyelet on one end to attach to. That hand lever is on the console beside the seat.
I ordered the one I linked at surplus center for $19.99. I'll see if it works when it arrives
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
Informational Lot - Shipping (A52128)
Informational Lot...
2016 Ford E-350 Enclosed Service Van (A50323)
2016 Ford E-350...
2006 Pearson Quantum Fire Truck (A50323)
2006 Pearson...
2013 Isuzu NPR-HD 16FT Reefer Box Truck (A50323)
2013 Isuzu NPR-HD...
