Loader BENT BUCKET
   / BENT BUCKET #11
Do you have a welder, and a torch?
   / BENT BUCKET #12
Put one or two of your forks on upside down in the centre. Just down pressure with the loader probably won't be enough but try it first anyhow. Then if you need to find something to wedge it under and use those forks like a big pry bar. I have lifted sheds with my little tractor by putting a block of wood behind the forks and pushing down while curling back the loader. You just need to find something that would let you do this in reverse.
Try putting a scoop of gravel in the bucket first.
   / BENT BUCKET #13
I like the wood splitter idea. With a little ingenuity it would work.
   / BENT BUCKET #14
Buy a new bucket save yourself the trouble
   / BENT BUCKET #15
You want to send him a check to pay for it? The bent bucket doesn't really hurt anything except his pride anyway.
   / BENT BUCKET #16
That's fine I have nothing against using a bent bucket... but he asked how to straiten it... aint happening
   / BENT BUCKET #17
I think you are out of luck.
There are some good suggestions but metal stretches when it bends.
You can use the ideas above but close is all I would expect.
I tend to over use (abuse) my equipment. I can not see me ever using clamp on forks.
Good luck!
PS I bent my bucket (abuse) and I cut out the bent areas and welded in new flat metal.
   / BENT BUCKET #18
Good luck!
I bent my box blade and you can't even tell it is bent and it was bent at least 2-3" in the center. Just pushed it back with no heat and used a log splitter. Medium to heavy duty BB.
   / BENT BUCKET #19
That depends on how straight you want it. If you want to use a dial indictor to check it, then yeah it's always going to be bent. I'll bet you the price of a new bucket I could greatly improve on the current condition of it. I have straightened out enough bent implements to know it can be done.
   / BENT BUCKET #20
I'd do it with no heat if you don't have a log splitter just place something under the bend in the bucket press down with the weight of the tractor and beat is straight pounding on either side close to the bend or drive up against something with the bucket curled up and push it straight. btw these are just opinions things I'd try I've straighten a few things but never a bucket. Sounds like Deere Dude has a good idea.
2022 Case IH 8250 Axial-Flow Combine (A53485)
2022 Case IH 8250...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2024 JOHN DEERE 6110M LOT NUMBER 56 (A53084)
2024 JOHN DEERE...
2008 CATERPILLAR 272C SKID STEER (A52705)
2008 CATERPILLAR...
PALLET OF (2) SPRINGS (A55745)
PALLET OF (2)...
