ATF in place of UTF, for tractor?
   / ATF in place of UTF, for tractor? #32
I think any of JD HyGuard 20 series are rated for pour point way colder than 32F. Mobile makes a good one too, I think the number is 424. Amsoil does market a synthetic, as does Ventrac, but way $!
prs
   / ATF in place of UTF, for tractor? #33
You are correct about Mobil 424. It's best to stick with the major brands that have genuine approvals.
   / ATF in place of UTF, for tractor? #34
I guess what I am asking is there a utf that ALSO meets the 303 spec? The tractor supply utf that meets the JD 303'spec also meets the j20d spec but it's for 32 degrees or better. I think most of us yanmar owners in cold climates want to meet the original spec and have better cold weather viscosity. A heater block is not an option for many of us as well. Super S SuperTrac 303 Tractor Hydraulic Fluid, 5 gal. - For Life Out Here
   / ATF in place of UTF, for tractor? #35
We will be switching out to Shell S4 TXM. Not worth the risk of running ATF.
   / ATF in place of UTF, for tractor? #36
I'm not sure what you are looking for. The JD 303 spec claims are meaningless since no one can prove that a given fluid does or does not 'meet' the obsolete specification. As far as low temperature goes the J20D requirement is 20,000 cP max at -40C which is the same or similar to that of many modern ATFs.
... which is the same or similar to that of many modern ATFs.
Ok, we've come full circle back to the question I started this thread with.
I've seen dealers and customers say ATF is better than UTF assuming light utility tractor application. (Not ag tractor heavy continual pulling). Mostly because of better low temperature characteristics. I remain curious if there is a practical (not 'could be') difference.
   / ATF in place of UTF, for tractor? #38
The big difference is that, as I think someone else mentioned, ATFs do not contain anything like the amount of anti-wear additive that UTFs do. Hence an ATF does not offer as good a level of gear protection.
   / ATF in place of UTF, for tractor? #39
Nor extreme pressure, like for rear ends. You dint see many diffy spec'ing ATF instead of gear lube.
Uh ..With the exception of modern front wheel drive passenger cars? ATF seems sufficient for these. A utility tractor used mostly for loader work etc won't pull hard all day like a row tractor would, so the stresses in its differential might not exceed ATF capability. (Obviously real gear lube is what you need in an application of frequent heavy pulling).
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2022 MACK GRANITE TANDEM AXLE DUMP TRUCK (A54607)
2022 MACK GRANITE...
2005 Greatdane Trailer (A52377)
2005 Greatdane...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
2006 TerraGator 8104 (A55301)
2006 TerraGator...
