Chevy 6.0 starting issue.
   / Chevy 6.0 starting issue. #1
NS Gearhead
Nova Scotia, Canada
Deere X350
It's a 2006 Chevy 2500HD, 6.0 gas. I've had this truck since the summer, and I'm on my 5th or 6th starter. Carquest rebuilds, lifetime guarantee. It'll work great until one day I try starting and get nothing. No click. Lights dim, but that's it. I've tried tapping the starter, boosting, disconnect and reconnect the battery... nothing. If I leave it for a couple days it may or may not start when I re-try. It's always worked again once the starter's changed... but sometimes only for a couple of weeks. The last time it was in the shop (because it started the one time so I drove it there), they found the ground wire was corroded and cleaned it up. Now, that visite it was working fine for them before cleaning the ground, and had worked for me until this weekend when it did the exact same thing. Had to change it in the snow. This time I added my own ground cable from the starter's bolt to the frame. Someone said this might help... worth a shot. I only used 16g because it's all I had, but I could upgrade to something heavier if I should. All I can think to do next time is to try jumpering the starter with a screwdriver. If it works I'll run a momentary switch from the starter to the cab and call it done. Any ideas what my issue is? It's become beyond frustrating. I can't depend on the **** thing... even though I have people that need me to plow them.
   / Chevy 6.0 starting issue. #2
   / Chevy 6.0 starting issue. #3
I had a Lincoln that had loose shifter linkage that wasn't allowing the car to shift all the way into park. The neutral safety switch then prevented the starter from engaging. Next time this happens, drop the truck into neutral and try starting it. Maybe the neutral safety switch is failing. They are on the transmission and guys who plow often get snow and moisture up in that area.
   / Chevy 6.0 starting issue. #4
Went thru 3 "lifetime" alternators from AutoZone before I got tired changing them and got one somewhere else. end of problem.
Sorry, forgot to say i'd tried it in neutral as well... no change.
Mechanic just tried the starter on the bench and it worked fine. Could it work on the bench and not be good or strong enough for the truck? If that's the problem I would think the solenoid would click at least.
   / Chevy 6.0 starting issue. #6
Goes back a few years, but I went through the same thing on my 1995 Chevy. Replaced with an AC Delco (OEM) and haven't had a problem in the last 15 years. I wouldn't hack up your truck for a ***** starter. Pony up for the Delco and be done.
Yeah, I was leaning towards trying that this time... AC Delco and everything... until I hear the difference was $300, but it may come to that next time.
   / Chevy 6.0 starting issue. #8
Boy there's a lot of complaints about this on the GM boards....
   / Chevy 6.0 starting issue. #9
id look at all the load carrying cabling, connection points, including those hidden in the harness. if this is a snow/salt area, a crimp connector might be real bad, and the act of changing the starter moves the cabline around to work till it corodes again.
make sure the mating area is good and clean too. adding a extra ground is nice, but 16g is peeing in the wind.
Lastly, make sur ethe vehicles battery is up to it. I have seen batteries that startt good one day and not the next. do a voltage drop test. if your bat drops past 11 check it. if it hits 8-10 you have a huge issue.
next check is to make sur ethe start line fromthe key is really going hot AND is carrying sufficient current to activate the relay/solenoid.
a volt meter alone will tell voltage.. but i'd load test it with something in the 5a range..
What gage would be good? I've got electricians at work that could make it for me no prob.
I plan to clean the battery connections today, then next time it happens swap batteries with one of my cars, just to confirm. Then screwdriver across solenoid posts. I've got a mobile heavy equipment guy willing to come have a look next time as well... so that's something.
2015 Jeep Renegade Latitude SUV (A50324)
2015 Jeep Renegade...
2015 Chrysler 200 Sedan (A50324)
2015 Chrysler 200...
KUBOTA M7-132 (A53084)
2017 TRANSCRAFT TANDEM AXLE DROP DECK TRAILER (A52576)
2017 TRANSCRAFT...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
2014 KENWORTH T800 (A52472)
2014 KENWORTH T800...
