Huber M-500 Road Maintainer
   / Huber M-500 Road Maintainer #1
tscott8201
Keystone Heights, Fl
Branson / Huber
Anyone have experience with Huber equipment? I'm about to look at an M-500 and was hoping to hear any common problems or things to watch out for.
Tom
   / Huber M-500 Road Maintainer #2
Tom,
Welcome to TBN!!!
What is a M-500 Road Maintainer?? Do you have any pics? Members on here love pics!!!!
Sure, here it is.
   / Huber M-500 Road Maintainer #4
biggest thing is pins and bushings in the blade raise the blade and see how loose it is a little is alright but a lot of movement will have to tightend up
Greg
   / Huber M-500 Road Maintainer #5
Nice looking machine! I would love to have that! I ran one of those over 30 years ago. Check the brackets that the moldboard slides thru for wear, especially the bottom of the brackets that the round tube slides thru and also the tube its self for flat spots on the very bottom. Nothing worse than having the blade fall off when back blading. Also check the rear end for noise, if I remember right, that has drop finals and there is a gear in there that fails. At least we had one go out. But our Huber had a loader bucket on it so it got a lot more abuse.
Mark
Looked at it this morning. Pictures make her look a bit better than she is as far as the finish goes. Owner had a sandblasting business so he had it blasted and painted which makes it look pretty good from 10'. Body panels are all there it appears and in decent shape. Not a show piece but for a 1970's road grader, not too bad. Everything but the brakes work, needs a new master cylinder, and she fired right up with no choke in 30 degree weather. She had been sitting in the same spot at least 2 weeks and I saw no major hydraulic leaks to speak of other than a small drip spot under the left raise / lower cylinder. All together I was pretty happy, so I think I got a pretty good deal at $4k. He also offered to deliver her since all I had was an 18' car hauler to pick her up with and the fit would have been kinda tight I think. I'll try to get better photos up soon after I take delivery.
Tom
   / Huber M-500 Road Maintainer #7
That's awesome Tom. Can't wait to see follow up pics. I started to say when Spring comes you can work it. But then noticed you are in Florida. You can probably put it to work immediately!!! :)
   / Huber M-500 Road Maintainer #8
Tscott8201, you must live down the road from me, I drive by that very machine on Sr21 twice a day.
   / Huber M-500 Road Maintainer #9
Friend of mine has one of those, amazing the job it does !
Small world I guess. We've been discussing the need to hire a grader for the road and then I drive by the Huber and it just seemed like fate. I was already in the process of selling a truck we had and it all just fell in place.
2018 Kubota U17 (A53317)
2018 Kubota U17...
2011 CATERPILLAR CP56 PADFOOT ROLLER (A60429)
2011 CATERPILLAR...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2020 Ford Ecosport 4WD SUV (A59231)
2020 Ford Ecosport...
24in pin on excavator tooth bucket (A56438)
24in pin on...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
