Welding up shooting targets?
   / Welding up shooting targets? #31
I made/am making a steel target out of old rail road plates. It's a bit of pain plugging, welding, and grinding the 6 or 8 3/4" square holes in each plate. So, 150 grain SP 7.62x39 out of SKS from 40 yards left small craters, 9mm Makarov left only a shiny spot. uploadfromtaptalk1453422000253.jpg
   / Welding up shooting targets? #32
Are you sure you weren't shooting 45 colt shells in a 454 casull gun? A 454 casull ain't a big fluffy pussycat. It makes a 44 magnum look like a little girls gun.
Oh, I agree, but shoot that .375 JDJ and get back with me. Just a couple of rounds should do it.
   / Welding up shooting targets? #33
I made/am making a steel target out of old rail road plates. It's a bit of pain plugging, welding, and grinding the 6 or 8 3/4" square holes in each plate. So, 150 grain SP 7.62x39 out of SKS from 40 yards left small craters, 9mm Makarov left only a shiny spot. View attachment 454449
I suspect those railroad plates are just A36 mild steel. Probably OK for most pistol rounds for a while, and fine for .22LR will "curve out" eventually with high power rounds, and start throwing them back after a while. I am sure many high power rifle rounds would likely zip thru it.
   / Welding up shooting targets? #34
Yeah, I don't plan on shooting it with .270 win or 7.62x54r, but just for .40 s&w and 9mm Makarov. If it starts deforming, it's ok, I've only got maybe $1.00 in it, in grinding wheel. I lucked into 40 lbs of 3/32 6013 for $4 at an estate sale. Would have preferred 6011, but at that price, I couldn't not buy it. The plate is probably close to 5/8" at thickest point and about 3/8" at the thinnest, and was free.
   / Welding up shooting targets? #35
Did you have equal grips on both guns? A set of rubber grips and wood grips on one gun makes a big difference. I have wood grips on both guns. Was the weight on both guns you shot close to the same?
   / Welding up shooting targets? #36
Probably be fine for your pistol use, and if it wears out, just weld up another one.:)
   / Welding up shooting targets? #37
It has been about 15 years, I cannot remember how the Contender was set up. But the .454 I shot before was a six gun and it "rolled up" in your hand, It likely had light loads in it also. the contender seemed like it just came straight back. It has been a while. I mostly just remember the pain.. I am dying for you to try the .375JDJ and tell me if it is as bad as I remember. I remember thinking this is the worse thing I have ever shot. Handfull of He77.
   / Welding up shooting targets? #38
I'll talk a buddy into shooting it first. If it doesn't break his wrist or gives him a concussion then I'll shoot it.
   / Welding up shooting targets? #39
I'll talk a buddy into shooting it first. If it break his wrist or give him a concussion then I'll shoot it.
Test pilot.:laughing:
   / Welding up shooting targets? #40
AR500...3/8".....100 yards.....50 cal..........not a mark. I made a target out of a disk harrow blade....25 yds... 357 mag, 45 cal....no indentation....just peeled the paint. Be careful shooting steel.
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2025 JMR 40in Single Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A50322)
2025 JMR 40in...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
2016 Chevrolet Cruze Sedan (A50324)
2016 Chevrolet...
2006 KOMATSU D41P-6 CRAWLER DOZER (A51222)
2006 KOMATSU...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
