Battery Charger/Maintainer Mounted Under Tractor Hood
   / Battery Charger/Maintainer Mounted Under Tractor Hood #1
MarkF48
Gold Member
Massachusetts
Mahindra 2216
With the talk of hard starting in the cold, I'm giving thought to getting a Battery Tender to mount under the hood of my 2216. I have an AC outlet near the tractor for a magnetic crankcase heater, so having the AC plug from the charger accessible from under the hood might work out better than having a connector tail that attaches to the charger externally. What I'm not sure about is if the Battery Tender DC leads can remain connected to the battery while the tractor is running and charging the battery with its own system. The FAQ at the Battery Tender site doesn't seem to mention doing this.
Anyone have a semi-permanent charger wired into their battery?
   / Battery Charger/Maintainer Mounted Under Tractor Hood #2
I installed one that works similar to this 1.5 Amp Three Stage Onboard Battery Charger/Maintainer
Mine came with a mounting bracket that slides under the battery. The tender is permanently connected to the battery. When I want to use it I just plug it into the 110v extension cord hanging overhead. I always unplug it before starting the tractor. I wouldn't care for the one you are considering because it would be very difficult to easily access the battery terminals every time I wanted to hook it up.
   / Battery Charger/Maintainer Mounted Under Tractor Hood #3
Yes you can leave it connected. I use a maintainer on my SUV. It stays on the vehicle all the time.
No problems.
   / Battery Charger/Maintainer Mounted Under Tractor Hood #4
Iv suggested in the other threads and you may have done it but have you cleaned your ground connection were it meets the frame and the frame itself lately?
   / Battery Charger/Maintainer Mounted Under Tractor Hood #5
How cold is it? I've had no problems in the last 3 winters with temps down to -22F
My guess is that you've got summer diesel in a winter tractor ;) For me it's common to fill up in the fall with summer diesel and forget it until the winter when it starts to get thick causing a sluggish start. I then have that lightbulb moment, pour in the Diesel 911 (if it's real cold or the regular treatment if it isn't too bad) and problem solved! Ignition left, ignition right, wait for the light to go out and viola running tractor :)
   / Battery Charger/Maintainer Mounted Under Tractor Hood #6
Do you guys even read the original post? No mention of HIM having problems, just a thoughtful "plan ahead" preventative maintenance.
Great idea.
   / Battery Charger/Maintainer Mounted Under Tractor Hood #7
Good point ;) Seems I jumped the gun a bit. Nothing wrong with both a heater and a battery tender. We use them on our snocat (work not play) so it will be ready without surprises.
   / Battery Charger/Maintainer Mounted Under Tractor Hood #8
I don't have a good answer to your question. BUT I can offer that a simple relay with a 120vac coil could be installed on the tractor so that when you plugged in the 120vac cord its coil was also energized making the DC connection from the battery tender to the battery. As soon as the 120vac cord was unplugged the relay coil would be in the relaxed state and the battery tender would no longer be connected to the battery.
   / Battery Charger/Maintainer Mounted Under Tractor Hood #9
I would think the reverse current feature would protect it.
   / Battery Charger/Maintainer Mounted Under Tractor Hood #10
Isn't that a reverse polarity function to stop from hooking up to the wrong post?
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
2008 CATERPILLAR D6K LGP PIPE LAYER (A50854)
2008 CATERPILLAR...
LINDE H80D FORKLIFT (A50854)
LINDE H80D...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
