Battery Charger/Maintainer Mounted Under Tractor Hood
   / Battery Charger/Maintainer Mounted Under Tractor Hood #11
Isn't that a reverse polarity function to stop from hooking up to the wrong post?
Yes but that is not a reverse polarity...its a battery drain protection.
Acoording to Battery Tender web page
Q.What happens if the AC power is removed from the Battery Tender Plus battery charger while it is connected to a fully charged battery?
A.If the battery is fully charged, then the Battery Tender Plus battery charger’s green light will be on. Once the AC power is removed from the Battery Tender Plus battery charger, the green light will go out and the charger not have any effect on the battery. The Battery Tender Plus battery charger is protected from reverse current, so it will not discharge the battery.
http://www.batterytender.com/Frequently-Asked-Questions/
   / Battery Charger/Maintainer Mounted Under Tractor Hood #12
I've got a tender hooked onto each of my twelve machines that have batteries.
   / Battery Charger/Maintainer Mounted Under Tractor Hood #13
Battery Tender - Frequently Asked Questions
Yep, been a while since I read one of their manuals. That makes sense, and answers the OP's question.:thumbsup:
Baker's dozen, eh?!:)
   / Battery Charger/Maintainer Mounted Under Tractor Hood #14
Had a OEM battery on the 3510 last over 11years with a Battery Minder on it. I use them on all my batteries including my 2500 Diesel with 2 batteries running on 1 tender. Have to test batteries to see if they are weak! Better than not cranking!!
Woods 7200 3 pt Finish Mower (A50514)
Woods 7200 3 pt...
2001 DITCH WITCH JT1720 DIRECTIONAL DRILL (A51242)
2001 DITCH WITCH...
JOHN DEERE 85G EXCAVATOR (A51242)
JOHN DEERE 85G...
2015 Kenworth T400 T/A Vactor 2100 Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
2019 Dodge Journey SUV (A50324)
2019 Dodge Journey...
CATERPILLAR D6R XL CRAWLER DOZER (A51406)
CATERPILLAR D6R XL...
