3 PT BH or Skid Steer BH??
   / 3 PT BH or Skid Steer BH?? #1
Highflier
Navasota, Texas
M9540
Trying to decide which way to go for a backhoe.
Buying a 3 pt mounted one for my JD 4720
Or a skid steer mount for a Bobcat T650 I will be buying in the next week.
Main question is which will mount/install faster and any pros or cons to either.
The JD would be the 485 and the Bobcat would probably be the 9BH
Thanks
   / 3 PT BH or Skid Steer BH?? #2
Why the skid steer backhoe? Are you planning on mounting it on the FEL? 3 point hitch backhoes suck. A backhoe with a subframe is the best.
   / 3 PT BH or Skid Steer BH?? #3
Your tractor is supposed to use a JD 485 backhoe. The Bobcat backhoe is significantly stronger than the JD 485. This is a great recipe for disaster. The skid steer made to handle that backhoe weighs 9,500 pounds. Your tractor weighs 3800 pounds plus the loader. A skid steer backhoe might work, but not that one.
   / 3 PT BH or Skid Steer BH?? #4
The OP question was the Bobcat Track T650 with the Bobcat BH, or buying the JD485 for the 4720..
In my opinion the Bobcat is a better choice at 9000Lbs for a BH and a higher Hyd flow rate and will have higher capacity digging, and probably easier on/off.
With the Bobcat BH can you maneuver the track/machine from the BH seat as you are digging? - if not this would be a big disadvantage to have to dismount the BH seat to move as you dig..
I would not put a 3PT BH but would do a sub frame BH on the JD4720 tractor - with a 4PT pin/cradle mounting setup this would be similar to install as the Bobcat also - probably not as easy as the Bobcat.
Then the transport - if you need one machine to do multiple tasks at a job site, the bobcat may give you more flexible options to have a grapple, a BH, a bucket, and broom etc. on a trailer to use as needed.
   / 3 PT BH or Skid Steer BH?? #5
The way I understood his post he was wanting to put the bobcat backhoe attachment on his tractor.
Thanks for the replies.
To clarify, I have a JD4750 as option A for a backhoe
Option B is a Bobcat T650
   / 3 PT BH or Skid Steer BH?? #7
Thanks for the replies. To clarify, I have a JD4750 as option A for a backhoe Option B is a Bobcat T650
I'd probably go with the Bobcat as its a stronger backhoe.
   / 3 PT BH or Skid Steer BH?? #8
How close to the $$ of a used mini-ex would the BC hoe be?
   / 3 PT BH or Skid Steer BH?? #9
Thanks
The hoe on the deere is a toy compared to the hoe on the Bobcat...
How tough are the jobs you have planned? Are they tough jobs?
SR
2014 International Durastar 4300 Terex BT3063 63ft 15 Ton Crane Truck (A50323)
2014 International...
John Deere LA110 (A50121)
John Deere LA110...
2018 Chevrolet Camaro 1LT Coupe (A51694)
2018 Chevrolet...
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
2013 Ford F-250 Animal Control Truck (A50323)
2013 Ford F-250...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
