Best 1/4" hex to socket adapters.
   / Best 1/4" hex to socket adapters.
Really don't want to buy another $100 tool if the impact adaptor bits were actually good for the torque claimed.
   / Best 1/4" hex to socket adapters. #12
Yep I agree with that. The 1/4" adapters I used were all fine for running up nuts but not much more than that.
Yep, that's what I'm talking about. But they make the hex to 3/8 square and hex to 1/2 square also
   / Best 1/4" hex to socket adapters. #15
I first saw this Milwaukee recommended by a full time mechanic. I haven't picked one up yet though so I can't say if they are as good as the reviews. They might be worth a shot if you haven't tried that brand yet.
   / Best 1/4" hex to socket adapters. #16
You have to wonder if a shorter length adapter is better or does really make no difference? The Bosch and the Milwaukee Shockwave 1/2 drive adapters are only 2 inches in overall length and the Milwaukee 3/8 shockwave is just 1.85. And both the Milwaukee 1/4" and 3/8" adapters leave just 3/4" of shank between the collet and the bottom of the socket. I don't have the 1/2 inch Shockwave to measure
The Titan and TSC ones are longer so both those have 1-1/4" of shank exposed.
Not many seem to advertise a specific torque value but I see the Dewalt 1/4 inch drive adapter list a 2000 in/lb (166 ftlbs) rating on both the 3/8 and 1/2 size. Doesn't give an overall length though that I can see
So is there a specific spot adapters usually break or is it just a random thing.
I'm guessing for the price of most 1/4 hex socket adapters you have to pretty much consider them as a disposable wear item if they do break. :confused3:
I have a 6 inch long Milwaukee quick load extension not exactly designed for square drive sockets but can always jury rig something up in a pinch with an adapter. But I don't care to break it either its easy to wreck a spring loaded quick release holder using an impact driver. And at $10.00 each they are not all that cheap. :eek: That one came as part of Shockwave bit kit. There are also a 3inch and a 12 inch available.
So while working on my riding mower recently using a socket with short adapter on my impact driver (seems that I never grab a ratchet anymore :laughing: ) I began to realize I just couldn't easily reach what I needed to. Got me started thinking maybe having something x-tra long like these 6 inch socket extension just to have around or put in my work tool bag if needed. No clue how they might hold up. I also looked at some wobble extensions but reviews were pretty mixed on those. :confused2:
I read some where that using long extensions and drive adapters actually reduce the power load to the fastener.
   / Best 1/4" hex to socket adapters. #17
Torsional windup on the longer ones limits torque. ... So the longer ones should be more durable. :confused3:
   / Best 1/4" hex to socket adapters. #18
After a while when they are stressed enough times I think the metal just fatigues and breaks
This ^^ you can't expect that little 1/4" shank to take too much for too long.
I view them just like a phillips head bit, desposable.
   / Best 1/4" hex to socket adapters. #19
If your impact driver is breaking adapters running loose nuts and bolts, use a drill instead.
Bruce
I would expect something with a 2000 in/lb rating to last a very long time on a impact with 1600in/lbs torque.
Bruce
Dont want to have that wrist breaking jolt when the nut snugs down. and the drill is not nearly as light or compact
(40) Collectible Watches in Box (A57453)
(40) Collectible...
Nortel Intelligent Peripheral Equipment (A56860)
Nortel Intelligent...
New/Unused Agrotk YC-26G Sawmill (A57453)
New/Unused Agrotk...
Billy Goat Multi Vacuum (A56860)
Billy Goat Multi...
SUV (A59231)
SUV (A59231)
Great Dane Van Trailer (A56436)
Great Dane Van...
