Argon cylinder that won't be filled again
   / Argon cylinder that won't be filled again #1
Jorville
Burnsville, MN.
WD Allis, Case 580 CK, HD5 Allis crawler, Bantam Koehring track hoe,
Went to a welding supply in st. Paul, MN. today and saw this argon cylinder. Never knew how they were made. about a third of the way down in the weld you can see a different look in the weld. there it looks like who or what ever welded this cylinder had a cold spot in the weld. Or are these cylinders a pipe with a top and bottom welded on. Anyone know if they X-ray these cylinders before they are put into service?
   / Argon cylinder that won't be filled again #2
I have never heard of a compressed gas cylinder being welded. I am not a professional welder but, as a retired chemist, I used compressed gasses from cylinders (primarily helium and argon) at 2500 psi. As part of our safety training, I saw videos of cylinders being constructed; there was no welding. Starting with a block of red hot steel, it was stamped, drawn and molded into its shape. I don't know what to make of what looks like a ruptured weld in your pic. I hope someone else chimes in.
   / Argon cylinder that won't be filled again #3
That looks like it froze somehow
   / Argon cylinder that won't be filled again #4
On, "How It's Made".. They show just what the previous poster said. They are drawn not seam welded like a pipe. There is no weld where this cylinder let go.
   / Argon cylinder that won't be filled again #5
All high pressure cylinders are drawn rather than rolled and welded since around 1970. This tank looks like it failed a hydro test. Had it ruptured when full much much more damage would have occurred.
   / Argon cylinder that won't be filled again #6
Going to want to use the good duct tape on that one !!
   / Argon cylinder that won't be filled again #8
That looks a lot like brittle fracture. This occurs when cold water is used when testing especially on alloy materials. I have seen large vessel rupture the same way from brittle fracture. When I say cold water I mean in the 60F range. It doesn't take a lot of temperature differential to cause this problem when high pressures are used for testing.
Brittle fracture also works in reverse when warmer water is introduced into a cold vessel like when the ambient air is below freezing and 60F water is used for the hydrotest.
2008 Ford E-350 Versalift 29N 29ft Bucket Van (A55788)
2008 Ford E-350...
More info coming soon! (A50322)
More info coming...
2011 Ford Transit Connect (A47477)
2011 Ford Transit...
Eagle Weathervane (A55758)
Eagle Weathervane...
FORD ROLLBACK TRUCK (A52706)
FORD ROLLBACK...
1969 Jeep 4x4 (A54865)
