Electrical advice needed
   / Electrical advice needed #1
TNhobbyfarmer
Middle Tennessee
Kubota L3430 Polaris Ranger 500
I am going to put a piece of woodworking equipment in my garage. It has a 220 volt 30 amp motor. I am going to need to install a 220 volt receptacle. Couple of questions: should the breaker in the box be 30 amp? Will I need 10-3 wire from the box to the receptacle. I assume a two pole breaker. I know just enough about wiring to be dangerous. Thanks for any advice.
   / Electrical advice needed #2
40 amp breaker, 8awg wire, never design a circuit to have more than 80% continuous load.
   / Electrical advice needed #4
It also depends on the equipment.
Does it need an independent ground in addition to the common?
Yes, it would be a two-pole/double breaker.
Not sure how to determine the answer to this question. Any advice as to how to determine if it needs an independent ground? What are the ramifications one way or the other?
   / Electrical advice needed #7
30a 240v motor??? What are you installing? Must be something big. Somebody already said 8awg (which I think is good to about 55a) but it ain't cheap.
   / Electrical advice needed #8
Without a cord ground, the frame can become energized in the event of a short. :eek:
   / Electrical advice needed #9
Hate to repeat but I have to wonder if it is 30a at 120v (like a typical nice table saw). As you double the voltage you half the amps. Makes a big difference. Again what are you installing?
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
1996 Elgin Pelican Series S Street Sweeper (A53421)
1996 Elgin Pelican...
FUEL PUMP W/NOZZLE (A53843)
FUEL PUMP W/NOZZLE...
