Ford 7600 Thermostart
   / Ford 7600 Thermostart #11
On finding mine on my 3000 the first time, I just followed the small tube from the fuel tank. You can watch it function on the 3000 if you pull the air inlet hose from the intake manifold and look inside. The coil will turn red, the valve will open, it will start slobbering fuel on the red coil and burning droplets of fuel will fall from it.....add some suction from the starter spinning the engine and wala.....fire in the hold.
   / Ford 7600 Thermostart #12
Yes, the cold start button on the fuel pump seems to be working OK. Just a lot harder to crank this winter than last.
"...harder to crank this winter..."
Is you battery and starter in good condition. Are the connections from the battery to the starter and the ground "bright and tight"?
Yes, the speed that it spins and time it will spin seems normal. The starter is only a couple of years old. That was replaced troubleshooting a starting issue that turned out to be an intermittent break in the wire from the switch to the solenoid. Very difficult to troubleshoot. That's why I checked that voltage was getting to the Thermostart.
2018 International Durastar 4300 Forestry Chipper Bucket Truck (A51692)
2018 International...
2018 HINO 268  NON CDL 26FT BOX TRUCK (A53426)
2018 HINO 268 NON...
2007 MACK CXN TANDEM AXLE DAY CAB (A53426)
2007 MACK CXN...
2023 G Bar K Goose Neck Flat Bed (A53473)
2023 G Bar K Goose...
Two Post Car Lift (A50120)
Two Post Car Lift...
2015 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A51691)
2015 John Deere...
