Electrical advice needed
   / Electrical advice needed #91
If the appliance is a cord connected device, the requirements for motors does not apply. As an example your 2 HP circular saw would require a very different circuit compared to a normal outlet.
If you install the circuit with a 30 amp socket (6-30 only 240v, or 14-30 for 120/240) and put a mating plug on your shaper, you are completely legal.
Paul
   / Electrical advice needed #93
Wondering the same thing. I never posted the manufacturer. It is not a Grizzly.
Guilty as charged... I posted it as an example of an industrial grade machine that a home owner might get their hands on. I am an electrician at present, but did not feel qualified to partake in the "Discussion", So I sat back and enjoyed the show... :laughing:
   / Electrical advice needed #94
Go to Lumberjocks.com and bring up any question about electrical...like ants at a picnic! Still don't know the exact machine the OP is installing...molder/planer I think which brings to mind the old Foley/Belsaw...at one time they also cut the knives for any profile you wanted. I think it since got copied into a smaller machine Woodmaster. The old iron...a friend got an old industrial air compressor...the motor came with 2 big capacitator "tubes" that we can't find replacements for...motors have evolved I guess.
   / Electrical advice needed #96
I envy you! You must have a lot of lumber available to make it work (or you just want to goof around). You never did answer how you plan to get rid of all the chips/shavings!:) Expect A LOT. That company is still in business so I'm sure you can trust their specs.
   / Electrical advice needed #98
Thanks for the tip on another great website!
You're welcome...typical site with the usual number of "snipers" but overall when it comes to home woodworking stuff you'll get a lot of opinions/advice.
   / Electrical advice needed #99
Capacitors are as generic as socks. Going higher on both the voltage and mfd is better.
   / Electrical advice needed #100
Agree but it has been fun watching the "experts" complicate things.
Same goes for pulling pulling up to the pumps . It's a truck, fuel is fuel, just grab a pump and fill'er up. Tires , as long as they hold air. These concerns about tread depth, matched in size or mixing bias and radial are bogus. Welding ? Doesn't matter what rods and current. Just stick it together , it's just welding.
Why let the experts complicate things ?
Mini trencher attachment (A53421)
Mini trencher...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2019 INTERNATIONAL...
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
