Electrical advice needed
   / Electrical advice needed #82
YESSSSS!!!!!
But some (notably B&D) do know a LOT more than the equipment manufacturer.
Can't trust B&D...he still beats his wife:laughing:...But you have a point on "advertised" hp. Never knew it was an issue on other than "universal" motors (those "whiny" ones found on portable power tools like routers and such).
   / Electrical advice needed #83
Wondering the same thing. I never posted the manufacturer. It is not a Grizzly.
Diesel crawler gave you your answer on post #2 don't make it any harder than it is.:)
   / Electrical advice needed #84
Noted earlier...when it comes to electrical, the board lights up...usually with something that reminds me of "I wanted the time of day...several people told me how to take my watch apart and put it back together". With that out of the way I'll agree that you never did specify the brand nor the specs. You acquire a "vintage" machine? If so you might want to consider a "sparky"...that "old iron" was a lot different than the new stuff.
   / Electrical advice needed #85
My bad... I got caught up in all the excitement and didn't notice that the Grizzly equipment was mentioned by someone else.
Turn off your computer and call your electrician relative :mur:
   / Electrical advice needed #86
Watches operate on a little bitty battery, not 240VAC.
   / Electrical advice needed #87
Same here....
   / Electrical advice needed #88
I don't want to derail a thread, but have one question. I have a 1-1/2 HP table saw and can run on 120 ore 220. Any advantages on running 220? It is 110 right now and works fine.
One advantage is that it will free up some 120v circuits if any one else is using your shop. Another is that the motor may start faster. Otherwise, you will use the same amount of electricity (watts).
watts = volts x amps 120v x 14 amps = 1680 watts
240v x 7 amps = 1680 watts
   / Electrical advice needed #89
Less VD, Time to spin up to speed will be slightly less. Ability to carry brief overloads will be improved. Considering the "same sized" wiring and typical electrical service. If you take the existing wiring, motor, breaker panel and swap the breaker, receptacle, plug and motor to 240V from 120v.
CHALLENGER VACUUM PUMP (A53843)
CHALLENGER VACUUM...
2014 CATERPILLAR 336EL EXCAVATOR (A52705)
2014 CATERPILLAR...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A53473)
NEW 2024 LOAD...
2018 CHEVROLET SONIC (A53843)
2018 CHEVROLET...
