Ingersoll 4020 Won't Start
   / Ingersoll 4020 Won't Start #1
smartdog
No Stonington, CT
Kubota 3240
My 1997 tractor won't start. Battery is good. When you turn the key, the starter would click, but that's it. Sounded like a solenoid issue, so I bought a new starter-still same thing, just a click.
Doesn't seem to be the neutral safety switch, as it does click. PTO is off. Any Advise?
I removed battery cables & cleaned them very well. Also sanded the ground & starter connections. Check the battery voltage with a meter, all ok. Pulled the starter & tested, ok. Finally called the shop. They came to look at it: an hour later they said, can't find anything wrong, other than it won't start. I'll have to load it & bring it in.
After quite a few hours on it, they repaired a number of wires, & replaced the key switch. I had mice which chewed the wiring in a few spots, which required a lot of disassemly to get at. Big repair job, & big bill.
   / Ingersoll 4020 Won't Start #4
Thanks for the update.
Hope they can fix it quick. :thumbsup:
LOL, that's what I thought about the starting.
Since most of the wiring/grounds/connections have been checked, I'm going to try a regulator.
Spent more than $1000 on it over the last few years, and I only use it for splitting wood.��
   / Ingersoll 4020 Won't Start #8
Instead of buying a regulator, why not use your multimeter and find out if it is working?
   / Ingersoll 4020 Won't Start #10
Start with the voltage measured on the battery posts, not the cable clamps.
Then start the engine and see how much it goes up.
I don't know what type charging system your tractor uses, but this might help: YouTube
(7) Front Tractor Weights (A46502)
(7) Front Tractor...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A48561)
80in HD Tooth...
3051 (A49339)
3051 (A49339)
3090 (A46502)
3090 (A46502)
45in.x15in.x20ft.Feed Bunk (A49339)
45in.x15in.x20ft.Fe...
2098 (A49339)
2098 (A49339)
