Curtis Snow Plow (Kubota V4208) Hydraulic Lift Conversion
   / Curtis Snow Plow (Kubota V4208) Hydraulic Lift Conversion #1
tlj87
Gold Member
PA
JD 4700, Kubota BX2370-1, Kubota RTV1140CPX, Kubota F3060, Club Car Precedent
I decided to replace the linear actuator used as a lift on the used Curtis snow plow I picked up for our Kubota RTV 1140 this summer. I had larger skid shoes added to the Curtis snow plow (From a Kubota BX snow plow) and the linear actuator could barely lift it.
I used existing parts from the Curtis setup including fittings and couplers from the hydraulic angle kit, the wiring harness and relay from original electric lift.
I ordered the following parts, all from Surplus Center:
QTY ITEM# DESC
(4) 9-6314 1/4" NPT QUICK COUPLER
(1) 916-1430 1/4" X 30" X 1/4 NPTM X 1/4 NPTM 3000 PSI HOSE
(1) 916-1424 1/4" X 24" X 1/4 NPTM X 1/4 NPTM 3000 PSI HOSE
(4) 9-5924 1/4" NPT QUICK COUPLER TIP
(4) 9-6806-8-6 SAE 8M X 3/8" NPTM 90 ELBOW
(2) 9-6805-6-4 SAE 6M X 1/4" NPTF 90 ELBOW
(2) 9-6405-8-4 SAE 8M X 1/4" NPTF ADAPTER
(4) 9-5405-4-6 1/4 NPTM TO 3/8 NPTF ADAPTER
(2) 9-5404-4-4 1/4 NPT HEX NIPPLE
(1) 9-7706-4 1.5X4X1 DA HYD CYL PINHOLE
(1) 9-5117-A SAE 8 6 GPM DOUBLE SELECTOR VALVE 12 VDC P155544-2
I also had three pieces made by a machinist (my generous, helpful neighbor):
1 mount for the hydraulic block, 1 adapter (2 pieces) for the hydraulic cylinder to mount to the plow A-frame, and 1 bushing for the hydraulic cylinder.
A video demonstration of the final product may be seen here: https://www.youtube.com/watch?v=zMo_ZmdSXKs&feature=youtu.be
   / Curtis Snow Plow (Kubota V4208) Hydraulic Lift Conversion #2
If your interested in parting with your old actuator i sent you a PM let me know please.
Mark
   / Curtis Snow Plow (Kubota V4208) Hydraulic Lift Conversion #4
Thanks.I got your message and replied at the other place.I appreciate your reply but think I have one coming.If it falls through ill contact you.But im sure all will be golden.Ill keep it in mind.Figure out a price and pm me as i may have use for it on another project or a spare.Again thank you very much.
Regards
Mark Sibole
"you can never have to many spare parts"
   / Curtis Snow Plow (Kubota V4208) Hydraulic Lift Conversion #5
I owned Kubota tractors for the past 12 years. Left tractor world to go to skid steer which I've discovered has some down sides. Especially on snow on hillside.:shocked: Pondered how to solve issue(s) and considered chains and possibly snow tires for SS and plow for SS instead of bucket which always worked on 4wd tractors. Expensive, every thing for SS is more expensive than on tractors but is usually more heavy duty.
We've had a couple of bad snow years here in Ky and I live on a steep hill.
Neighbor told me he had a guy with a 4 wheeler and a front blade/plow clear his drive way. Got my mind to my RTV1140 as my snow machine and researched snow blades/plows yesterday for RTVs and seems the less expensive and maybe even better route for me is RTV for snow issues and keep the SS in the barn for summer, dry ground use.
See your post here and see your using a RTV1140. Advise, issues. concerns to consider? Found some plows/blades on Ebay for $500 (manual blade adjust) to $1000 Hydraulic blade adjust. Other going up from there. Going to check on price of Kubota V4291 but sur eit will be over $2000 for a use of 2 to 3 times a winter for a 400 foot concrete drive way. May venture out to doing brothers 60 foot drive that lives next door if the RTV does well.
Did you research before buying or found a plow and bought while the opportunity presented itself?
Any help or advise from anyone with a Kubota RTV900 to 1100 will be appreciated. Remember, I'm not in Minnisota or Montana but Kentucky, almost down south but not quite.
I owned Kubota tractors for the past 12 years. Left tractor world to go to skid steer which I've discovered has some down sides. Especially on snow on hillside.:shocked: Pondered how to solve issue(s) and considered chains and possibly snow tires for SS and plow for SS instead of bucket which always worked on 4wd tractors. Expensive, every thing for SS is more expensive than on tractors but is usually more heavy duty. We've had a couple of bad snow years here in Ky and I live on a steep hill. Neighbor told me he had a guy with a 4 wheeler and a front blade/plow clear his drive way. Got my mind to my RTV1140 as my snow machine and researched snow blades/plows yesterday for RTVs and seems the less expensive and maybe even better route for me is RTV for snow issues and keep the SS in the barn for summer, dry ground use. See your post here and see your using a RTV1140. Advise, issues. concerns to consider? Found some plows/blades on Ebay for $500 (manual blade adjust) to $1000 Hydraulic blade adjust. Other going up from there. Going to check on price of Kubota V4291 but sur eit will be over $2000 for a use of 2 to 3 times a winter for a 400 foot concrete drive way. May venture out to doing brothers 60 foot drive that lives next door if the RTV does well. Did you research before buying or found a plow and bought while the opportunity presented itself? Any help or advise from anyone with a Kubota RTV900 to 1100 will be appreciated. Remember, I'm not in Minnisota or Montana but Kentucky, almost down south but not quite.
JT, I responded to your new thread.
   / Curtis Snow Plow (Kubota V4208) Hydraulic Lift Conversion #8
   / Curtis Snow Plow (Kubota V4208) Hydraulic Lift Conversion #9
Have located a Curtis Sno Pro 3000 plow locally with "Curtis Quick connect?". Seller keeping inside wiring for his coming replacement larger plow. He's been using on a Dodge PU. How much trouble is it going to be to connect this to my RTV1140 mechanics/attachment/adapter plate wise? I know I'll have to buy inside controller and inside wiring harness.
2023 FORD F-650 SUPER DUTY CAB AND CHASSIS TRUCK (A59823)
2023 FORD F-650...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
DEVELON DL250-7 WHEEL LOADER (A59823)
DEVELON DL250-7...
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
2010 Specialized Structure 1456 (A56858)
2010 Specialized...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56438)
2012 MACK Tender...
