Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #2,902
I thought the same thing!
I once cut up a tree covered with poison ivy. Didn't think about it much because I hadn't had any reaction to poison ivy for the previous 25 years. Prior to cutting it up I was moving rounds by hand with a short sleeve shirt and had cuts all over my forearms. Anyway, long story short - spraying poison ivy directly into your veins is a bad idea! 2 weeks on steroids and my insides stopped itching!
We had a bit of a cold snap. Cold enough to get out and take out another tree that is in the way of my future gravel lane to the back of the barn without rutting everything up. Sadly, this small black walnut wound up as fire wood! :eek:
Most of my winter has been too warm (read muddy) to do much in the woods.
Regarding the previous top handle versus pole saw conversation, the only correct answer is both! :D
Lastly, a friend is tempting me with a saw... A Makita 6401 with a Dolmar 7900 head and the builder is offering a 2 yr warrantee all for $500. Should I go for it??? I already have a Dolmar 7900 and love that saw. But it would be nice to have two so that I don't have to change bars all the time. There is a down side... that is my wife probably wont appreciate me spending money on a saw I already have!!!
   / Tractors and wood! Show your pics #2,903
I will be sure to look more closely at the vines before handling them. Fortunately my friend with the sawmill is not bothered by P.I., and will gladly remove them for me. It is likely that I wouldn't need to handle the logs by hand much regardless. That's where the tractor part comes in!
   / Tractors and wood! Show your pics #2,904
been there done that. it was Feb didn't notice the vine were poison ivy vines i wound up on Prednisone, but only for 6 days. hopefully i learned my lesson
that is correct
yes CAD chainsaw addiction disorder is almost as bad as tractor addiction
   / Tractors and wood! Show your pics #2,905
Talked a friend into buying the other 7900 so that I don't. But if a deal comes along on a 395xp I may have to jump on that. I want something with a higher flowing oiler for my 37"'bar.
   / Tractors and wood! Show your pics #2,906
been there done that. it was Feb didn't notice the vine were poison ivy vines i wound up on Prednisone, but only for 6 days. hopefully i learned my lesson that is correct yes CAD chainsaw addiction disorder is almost as bad as tractor addiction
If I had a Stihl saw I'm sure I would soon develop CAD. I have a low tolerance for such things.
   / Tractors and wood! Show your pics #2,907
   / Tractors and wood! Show your pics #2,908
did some more wood(stump) removal todaydozer stump removal 1.jpgdozer stump removal 2.jpgdozer stump removal 3.jpg
Sure makes it easy when the ground is wet
   / Tractors and wood! Show your pics #2,909
As promised.... the tractor part of the equation
Slide show style... unloading the big log.
My buddy was as excited as I, even offered to buy them... but not quite enough to make me give up the board feet of lumber! I calculated about 650 BF between two bigger logs, last picture is big log and smallest firewood log.
2011 Toyota Corolla Sedan (A53117)
2011 Toyota...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A55218)
Galvanized...
2430 (A51248)
2430 (A51248)
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A55301)
Michelin CARGOXBIB...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
