Back on trailer ? Which is safer ? Dealer says on his lot you back on
   / Back on trailer ? Which is safer ? Dealer says on his lot you back on #11
My John Deere manual recommends backing on in case the hood comes unlatched. I haul forward because I like the point it balances better that way.
   / Back on trailer ? Which is safer ? Dealer says on his lot you back on #12
Did he also recommend chaining down a raised loader ? WOW .
   / Back on trailer ? Which is safer ? Dealer says on his lot you back on #13
Tractor aerodynamics are all wrong backwards :D:D:D
   / Back on trailer ? Which is safer ? Dealer says on his lot you back on #14
I backed my 4410 on once. The fuel door caught the wind and was gone when I got home. It'll never happen again.
Depending on what kind of a dealer you have I'd be tempted to look for a different dealer. If they have attitude about this there will be other issues too.
   / Back on trailer ? Which is safer ? Dealer says on his lot you back on #15
Never really thought about it. Usually I just pull my tractors on forward up to the nose of the trailer. Yes ik probably not distributed properly but I usual have more stuff to put on and they are narrow fronts so they are a bit lighter.
Yes Tim , photo is the day I brought it home , 30 months ago. Since then I don't back on. Dealer had his rules
Oh he had a attitude about it , his lot his way
   / Back on trailer ? Which is safer ? Dealer says on his lot you back on #18
If I am hauling on the rollback I back on because it puts more weight on the front of the truck. If I'm hauling on the gooseneck I drive in forward.
   / Back on trailer ? Which is safer ? Dealer says on his lot you back on #19
I backed trailers all my life almost and unless there is a compelling reason not to drive it on, I would drive it on. I find it is much easier to keep everything centered and all lined up straight when driven on. Then backing off there is less chance driving off the side.
To me it is like driving a truck through a 9' wide garage door and keeping it straight in the garage. It is much easier to back out straight than to back in straight. Maybe it is just my quirk.
Chain is not touching loader , they welded a U bolt at the hood guard for a 3/8 chain to go through
2018 John Deere 8270R MFWD Tractor (A53342)
2018 John Deere...
2005 CATERPILLAR D3G LGP CRAWLER DOZER (A51246)
2005 CATERPILLAR...
BESTWAY AG VSK35 LOT NUMBER 126 (A53084)
BESTWAY AG VSK35...
Lot of 2 Loader Tires (A51691)
Lot of 2 Loader...
2010 JOHN DEERE 1110E FORWARDER (A51246)
2010 JOHN DEERE...
City of Buckhannon - 2000 Chevy 2500 (A52384)
City of Buckhannon...
