SSQA pads fixed together vs not fixed together - why?
   / SSQA pads fixed together vs not fixed together - why? #11
Our JD 640 has such independent operation. A very stupid design! The hydraulic circuit to the one side is longer so the two sides never move at the same speed and unless full in or out, are never in the same location. Worse when oil is cold. Makes you wonder where they find these "engineers".
My cylinder just showed up, so I'll be bringing that with when I go up to the woods this weekend. :)
I looked at my loader today and discovered the pins are fine, but the holes just aren't tight to them.
This is as far out of time they'll go.
   / SSQA pads fixed together vs not fixed together - why? #14
Shouldn't be a problem if you allow for it in the cylinder mounts on the handles.
They will be in line when up against the attachment and rolled back, ready to latch.
This is how Bobcat did it on the Toolcat, two cylinders with very little slop because they can't move out of line, like your handles.
I could've gotten 2 cylinders, but all that'd do is slow things down.
I've got a couple options: build a frame to tie the pads together, or allow for some slop in my cylinder mount.
I'm leaning towards the latter. I can make a mount that goes over the timing tube and uses it for the fixed point with minimal work.
   / SSQA pads fixed together vs not fixed together - why? #16
Bobcat had to use two because one wouldn't clear the center linkage, I was just showing how it attached to the handle.
I see no reason to tie the pads together.
I don't understand the need for a fixed mount?
Each end of the cylinder goes on a handle.
   / SSQA pads fixed together vs not fixed together - why? #17
The latch arms are a heavy cast part that dwarf most other's designs. Post up yours. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=457433"/>
What makes your cast arms any better than others? Mine are 3/8 or 1/2 steel. I managed to bend one of mine pretty good. I took it off, threw it in the press and straightened it out. It now works fine and the fix didn't cost anything. Try bending cast and then bending it back into shape.
   / SSQA pads fixed together vs not fixed together - why? #18
You mean other than making it a lot easier to mount attachments.
Uneven pads look like it would be a PITA to mount attachments to me.
   / SSQA pads fixed together vs not fixed together - why? #19
How are you powering the cylinder.
   / SSQA pads fixed together vs not fixed together - why? #20
I thought the fixed mount was to mount the cylinder on. :confused3:
The uneven pads will line up when you push against the attachment, raise it and rollback before locking the latch pins.
Edit: Jim we need a picture of the cylinder, please. :)
John Deere 2700 5 Bottom Plow (A50514)
John Deere 2700 5...
2014 INTERNATIONAL LF687(INOPERABLE) (A50854)
2014 INTERNATIONAL...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
1262 (A50490)
1262 (A50490)
2007 TRANSCRAFT 48X102 FLATBED (A50854)
2007 TRANSCRAFT...
2006 GENIE GTH6622 TELESCOPIC FORKLIFT (A51242)
2006 GENIE GTH6622...
