My complete inability to make a pneumatic grease gun work !
   / My complete inability to make a pneumatic grease gun work ! #1
pokerboy57
John Deere 3320
One would think that a pneumatic grease gun should not bring a grown man to tears of frustration..... but they both did. I own 2 one from Lowes and the 2nd from Harbor Tools. On the surface the problems I am experiencing seem to happen with both the same. No grease comes out !
Basically I pull the plunger out to the maximum stop. But a newly purchase tub of grease in. Remove the "pop top" off the new tube of grease. Screw the canastor with the tube of grease back into the rest of the gun, release the plunger and pull the trigger. (Yes to hooking up the air line).
Lots of good air sounds when I pull the trigger but no grease comes out.... I've noticed that the plunger doesn't "feel" like it can go up into the open end of the tube of grease. In both guns it seems like the plunger cannot go into the tube only the rod that the plunger is on seems to be able to move up into the tube of grease.....
Guys I need some suggestions I am either going to "retire" both grease guns and purchase a new cordless gun or I will get these working in the next few days. Any secrets you can share with me how to get these air guns to work reliably would be very much appreciated. .
I want to save what tears of frustration I have left for my Federal Tax return.
   / My complete inability to make a pneumatic grease gun work ! #3
i just bought one at TSC. I found that the plunger doesn't fit inside the cartridge to push the grease up. i need to play with it more.
   / My complete inability to make a pneumatic grease gun work ! #4
I've been completely satisfied with the pneumatic Lincoln I've had for almost 10 years.
   / My complete inability to make a pneumatic grease gun work ! #5
Another vote for the pneumatic lincolns.
The piston should just press on the grease with spring pressure. The rod should travel the entire way to the top of the grease tube.
Try packing the head (hose end) of the gun with grease, it can sometimes work to help prime the pump. Also try running the rod in and out as it can help as well. Try storing your grease guns upside down. If its cold out, keep the gun somewheres a little warm too.
   / My complete inability to make a pneumatic grease gun work ! #7
I never seat the barrel into the head, when I put a new tube in, leaving it a tad loose to burp the air out, when I release the plunger. A couple of the guns I have, have like a 1/16" hole in the head of the gun, in the threaded part, to let air out. One other has a bleeder valve in the head to let the air out.
   / My complete inability to make a pneumatic grease gun work ! #8
The old greese guns with a lever are trouble enough. I don't think I want to try the pneumatic kind.:banghead:
   / My complete inability to make a pneumatic grease gun work ! #9
on my hand pump grease gun, i have to take to long trod and kind of force the plunge down into the grease.
   / My complete inability to make a pneumatic grease gun work ! #10
Some have a bleed button with a spring on top to bleed.On mine I have to make sure the plunger is entering the tube. If I try greasing with more than 80# air pressure the gun locks up so I set the pressure around 60#.
2017 FORD F550 XL SUPER DUTY BUCKET TRUCK (A51406)
2017 FORD F550 XL...
2021 Toyota Corolla LE Sedan (A53424)
2021 Toyota...
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
1979 MACK R MODEL WINCH TRUCK (A53843)
1979 MACK R MODEL...
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
