My complete inability to make a pneumatic grease gun work !
   / My complete inability to make a pneumatic grease gun work ! #11
Many times I learned the easiest way to get one to work is to take the hose/pipe off and put my finger over the hole and pump.
This will "BURP" it and when you feel just grease coming out put the hose back on and you are good to go.
I work on some machines that have two bearing areas that take 30 pumps EACH! When the gun is working.
I found a air operated Grease Pump on CL that takes a 5 gal pale and rarely have issues with it picking up the grease now.
   / My complete inability to make a pneumatic grease gun work ! #12
Yep, don't matter if hand pump, air, or battery.....you gotta vent the air
   / My complete inability to make a pneumatic grease gun work ! #13
After releasing the rod, the spring is forcing the rubber cup toward the guns head. I unscrew the casing from the head to release air. Then tighten the casing to the head. A few pumps and it works.
   / My complete inability to make a pneumatic grease gun work ! #14
Are you following the directions EXACTLY??
JOHN DEERE 6135RW401 MOTOR (A51247)
JOHN DEERE...
2000 JOHN DEERE 444H WHEEL LOADER (A52705)
2000 JOHN DEERE...
PIPE WRENCHES (A53843)
JOHN DEERE 3032E TRACTOR (A54756)
JOHN DEERE 3032E...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
2013 WESTERN STAR  4900 (A53843)
2013 WESTERN STAR...
