Oil for rotary mower gearbox
   / Oil for rotary mower gearbox #1
aarolar
Augusta Ga
Kubota MX4800
What oil s needed for a rotary mower gearbox? I bought my gearbox and built my deck and frame so I have no manual. Will just any good gear oil suffice?
   / Oil for rotary mower gearbox #3
My mower gearbox uses 80/90 as SSdoxie recommended.
Figured thanks
   / Oil for rotary mower gearbox #5
Yep, any good gear oil.
I use 85/140 on one of mine, and 00 grease in another. Light weight grease is usually okay too.
   / Oil for rotary mower gearbox #6
Yep, 80w90 or 75w90 synthetic. I usually have the latter on hand because of commercial truck use.
   / Oil for rotary mower gearbox #7
I like the synthetic too on new ones. I put it in and forget about it. On new ones (and surely upper end old ones) I like the fact that OEMs have started using ventilating fill plugs which allow the gearbox to breathe and take the pressure off the output shaft seal. Going to bet that a lot of current leakers wouldn't be leaking if the pressure was allowed to vent when it builds up.......for those reading and wanting one rather than the conventional ½" pipe plug, auto parts stores carry them, especially the neighborhood mom and pop shops in farming communities.
Thanks for the idea
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52706)
KNOW BEFORE YOU...
2019 FREIGHTLINER SPRINTER 2500 CARGO VAN (A54313)
2019 FREIGHTLINER...
2001 Ford F150 (A50121)
2001 Ford F150...
2017 HYDREMA 912HM ARTICULATED DUMP TRUCK (A52706)
2017 HYDREMA 912HM...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
