LD1
Epic Contributor
Just be cautious when hitching or chaining high like that
Yes I want it to be quick hitch compatible. I believe both of the Titan triangle type ones are.
I have the Titan triangle one and use it most of the time for exactly the same purpose as yours. And carrying a cargo tray. It is bullet proof.
However, I just got a Harbor Freight Quick hitch. I plan on welding a receiver hitch tube under the center of the top hook mount to keep that versatility and gain a quick hitch. The receiver tube cost me 8.95 at the local farm supply. Still have to get the hooks or a D ring to weld on at same time for chains/straps.
I don't know about cat 1 3pt, but my cat 2 is suggested to be set for 7" above grade at the lowest point. Quick math says you'll need a 6" drop draw bar at a minimum, and maybe even an 8" to make that configuration work for a 18" ball height.
I used an old jeep bumper I built to add a hitch to, and while it's not QH compatible, it's been very handy. Not having to use the trailer jack at all is enough to spoil a guy.![]()
I hadn't thought of the raised height making that much a difference. I think the quick hitch standard was 15" vertical and planned in running a 4" drop. I'll revisit that idea.
I just ordered the top link adaptor from HF and may just use the Titan triangle on the quick hitch if it all works together for the run around setup.The boxblade now has a receiver on it, and the bush hog and dirt scoop have no reason to be towing something ever.
I like the yellow version posted above. Lot of good ideas there.
It won't work without it on the triangle. It is a call in order only. I did it today. It was 12.79 after applying a 20% coupon. plus 6.99 shipping for me for total of 19.78 in 5-7days via USPS.
Agrisupply has it for 9.99 but the shipping was nearly 15 bucks. I think total was 24.32. I found it there by searching only the word quick hitch. There's one there for 19.99 but it's a class 2 I think with pins.
This is what it looks like.
And here is where I need it first for my scoop and I hope it will work on the triangle hitch.
Be prepared to have to grind that top hook of the quick hitch inside the throat. Everyone else has had to. I got what I could on the edges with a 4"grinder and then hand filed the center down that the grinding wheel wouldn't reach.
