What tractor are you using in your vineyard?
   / What tractor are you using in your vineyard? #21
This is the tractor I have been running the past couple days. My friendss JD 5310N. The tractor pulling the other cart is a NH TN75V
   / What tractor are you using in your vineyard? #22
I have blackberries and blueberries on 12 ft. rows. They grow out about 2 ft. so that makes it 8 ft. to get down. I use a Fendt 209P that I purchased used in Michigan. It is about 5 ft wide with tires on the narrowest settings. It works good. I use a 7 ft. mower.
   / What tractor are you using in your vineyard? #23
My vineyard tractor is a SAME, it's been a good tractor... I believe it will go down to 48" wide, although I keep it wider.
You may want to see if you have a SAME dealer...
SR
   / What tractor are you using in your vineyard? #24
Can you post some pics of your fendt including the operators platform?
LOT: (2) Dewalt Electric Drills, (1) Dewalt Electric Grinder, (1) Milwaukee Grinder (A59076)
LOT: (2) Dewalt...
2025 GPS Utility Trailer (A56859)
2025 GPS Utility...
2010 FORD F-150 (A58214)
2010 FORD F-150...
TANK MANIFOLD (A55745)
2025 JMR 66in Single Cylinder Brush Grapple Skid Steer Attachment (A56857)
2025 JMR 66in...
New Holland 650 Hay Baler (A53317)
New Holland 650...
