What tractor are you using in your vineyard?
   / What tractor are you using in your vineyard? #21
This is the tractor I have been running the past couple days. My friendss JD 5310N. The tractor pulling the other cart is a NH TN75V
   / What tractor are you using in your vineyard? #22
I have blackberries and blueberries on 12 ft. rows. They grow out about 2 ft. so that makes it 8 ft. to get down. I use a Fendt 209P that I purchased used in Michigan. It is about 5 ft wide with tires on the narrowest settings. It works good. I use a 7 ft. mower.
   / What tractor are you using in your vineyard? #23
My vineyard tractor is a SAME, it's been a good tractor... I believe it will go down to 48" wide, although I keep it wider.
You may want to see if you have a SAME dealer...
SR
   / What tractor are you using in your vineyard? #24
Can you post some pics of your fendt including the operators platform?
2003 Ford Pressure Digger Truck (A55973)
2003 Ford Pressure...
2011 Ford F-150 Crew Cab Pickup Truck (A56858)
2011 Ford F-150...
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Caterpillar 740 HT-129 Tanker, S/N CAT00740PB1P009728, Cat Turbo Diesel Engine, Tidal Wave Tanks ... (A59076)
Caterpillar 740...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
