Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #3,022
Hmmm... I'm no professional but have downed more than a few firs/cedars/hemlocks in my time and this is my 'formula' if I understand it right.
There's more than one way to skin a cat, that's for sure. Ever since I took a full day chainsaw class (I know that doesn't make me an expert) I started using an open face notch like this:
The goal is for the length of the hinge to be 80% of the diameter of the tree. This can usually be achieved only a few inches into the tree. No need to cut such a deep face cut. Follow this with a bore cut to set the hinge at the right thickness (10% of the diameter in most cases) and you're making good progress. Move the bar back away from the hinge leaving a small "trigger". Set a wedge in the kerf for good measure. Double check the landing zone, cut the trigger, tap the wedge if need be, and there she be.
   / Tractors and wood! Show your pics #3,023
Same here. Notch 80 percent of the width (diameter) followed with a bore cut.
   / Tractors and wood! Show your pics #3,024
I'm sure there's lots of room for improvement in my saw skills, and lots of better ways to do things I need to learn...
First, a bigger saw... the ol 025's I have do well, but are just not enough saw.
Longer bar... I had a 16" that day, I do have a 22" I use on special occasions when planned. Not the case that day, spur of the moment.
No wedges with me...
I'll get there, but it's a learning curve.
   / Tractors and wood! Show your pics #3,025
Thank goodness I'm not the only one here on the learning curve. No 24in saws but a cheap polun 14 in and 2 18 in huscqvarna and shil
   / Tractors and wood! Show your pics #3,026
Actually the learning never stops. The more trees you cut the more you realize that there are way to many situations for just one formula to be the answer. It is very very easy to totally miss-judge the lean and/or head lean and thus the natural direction of fall on a side hill. The important thing is once you realize the mistake you know how to get out of the situation safely like Greg did. One thing to keep in mind though is to be suspicious of your judgment if you think a tree is leaning uphill. Double check yourself. Trees lean up hill for sure but most trees want to fall down hill.
Sticking a wedge in the cut on any large tree is a good habit to have.
gg
   / Tractors and wood! Show your pics #3,027
Yep, I always slip a wedge in whenever possible.
   / Tractors and wood! Show your pics #3,028
I only have one wedge... somewhere. Need to toss it in the tractor tool box. Need to buy a few more too...
I got that poplar cut into 8' logs, 2 nice ones, about 20" diameter, the other 2 are not so nice, hollow in spots, and crooked. They might not make it to the mill.
   / Tractors and wood! Show your pics #3,029
Where to buy a decent couple/three wedges on-line? We have absolutely no place with wedges here locally. Big box stores don't stock them and its too urban so even the few lawn and garden shops that sell chainsaws don't carry wedges. When you ask, they all take you to metal splitting wedges.
   / Tractors and wood! Show your pics #3,030
TreeStuff - TreeStuff Felling Wedge
I picked this pack up a few weeks ago. I ordered on a Wednesday night and they were delivered the next day with standard shipping. I haven't put them to work yet, but they appear to be as good as the rest. Otherwise I would recommend amazon.
2017 JOHN DEERE Z950M LOT NUMBER 83 (A53084)
2017 JOHN DEERE...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2013 Vermeer BC900XL Towable Brush Chipper (A52377)
2013 Vermeer...
DOOSAN G25 GENERATOR (A53843)
DOOSAN G25...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
