fried1765
Super Star Member
- Joined
- Jan 6, 2015
- Messages
- 10,159
- Tractor
- Kubota L48 TLB, Ford 1920 FEL, 8N Ford, Gravely 12 HP "Professional", 48" SCAG Liberty
I've just purchased a 1953 Ford Jubilee for $1800. Runs good, has some oil leaks, almost sure it needs.a a front seal replaced. Does anyone know exactly what is a live PTO on a jubilee model.
You definitely need an "over running clutch".
Check your PTO shaft diameter, to be sure you buy the correct diameter/size.
The best one on the market is the "Eurocardan Pawl Clutch", but it is $86.95.
It has a push pin connect/disconnect (requires no tools to disconnect).
If you go to the Agri-Supply site you can find it under their UPC #67962.
If you do not want to spend that much, their UPC #12050 is a drive pin in/drive pin out ( hammer and punch) overriding clutch for $37.49, or you can buy one just like it at TSC.
I have had both types, but for the convenience of quick removal (with only your fingers), I MUCH prefer the "Eurocardan Pawl Clutch".
