ovrszd
Epic Contributor
- Joined
- May 27, 2006
- Messages
- 32,246
- Location
- Missouri
- Tractor
- Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
Not familiar with this specific tractor. So I'll just offer general information.
There are two types of Shuttles.
Synchro Shuttle or Mechanical Shuttle which is simply a gear shifting lever that is used to change direction. Clutch application is required. Older gear shuttles might not even be synchronized. My 1984 Ford is not synchronized.
Power Shuttle or Hydraulic Shuttle or Power Reverser as John Deere calls it is a lever that actuates a hydraulic clutch system that changes tractor direction. No foot clutch action is required. No gear grinding. Very smooth direction change. Lot easier to use in repetitive situations such as FEL work. My 2012 Kubota uses this system.
When comparing a Shuttle system to an HST system there are two large differences. The HST is much easier to operate. The Shuttle system takes much less HP to operate.
