Rear lift won't lift
   / Rear lift won't lift #1
ja1724
Hamden, CT
IH 2504
Hello All,
1967 IH 2504 rear lift works fine with full travel all the way up with light load (me on it ~ 200lbs) but when I try to lift my ballast box it only goes up about 4 inches. Can anybody please give me some insight here. Maybe where to look first? Poppet relief valve? I don't really know a whole lot about these rear lift mechanisms.
Thanks much.
   / Rear lift won't lift #2
Try an online search for a shop manual.
There are several on eBay.
Looks like it is the industrial version of a IH 504.
   / Rear lift won't lift #3
I'm just going to start with the obvious, is the fluid filled? When was the 3 point filters & fluid last changed?
DevilDog
DevilDog
The fluid is filled and was changed last summer along with the filter. As far as I know the main fluid reservoir is a shared tank for the tranny/gearbox, 3 point, power steering and FEL. Please correct me if I'm wrong but I think there is only one main filter for the whole hydraulic system.
   / Rear lift won't lift #5
Hello All,
Thanks much.
First of all - is this a new occurrence? Did it work before?
A hydraulic test kit is always handy.
   / Rear lift won't lift #6
Did anyone adjust the flow rate knob. On my mx5100 it is the knob under the seat. Had a grandson twist it closed once and I almost never figured it out!
I've tested it to see if the three point went up & down but never tried to lift anything until now. I think the FEL and the 3 point use the same pump (but I'm not 100% on this) so if the FEL works fine I would think the hydraulics to the back should work. Unless a relief valve is releasing to soon or some other issue.
Don't see any flow rate knobs. Maybe a way to adjust inside the lift unit but I don't think so.
12 Yard Rolloff Container (A51573)
12 Yard Rolloff...
2009 Chevrolet Traverse LS SUV (A51694)
2009 Chevrolet...
2004 MCI D4500 Passenger Bus, VIN # 1M8PDMPA54P056247 (A51572)
2004 MCI D4500...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
New/Unused CFG Industrial XZ20R Mini Excavator (A51573)
New/Unused CFG...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
