Rear lift won't lift
   / Rear lift won't lift #1
ja1724
Hamden, CT
IH 2504
Hello All,
1967 IH 2504 rear lift works fine with full travel all the way up with light load (me on it ~ 200lbs) but when I try to lift my ballast box it only goes up about 4 inches. Can anybody please give me some insight here. Maybe where to look first? Poppet relief valve? I don't really know a whole lot about these rear lift mechanisms.
Thanks much.
   / Rear lift won't lift #2
Try an online search for a shop manual.
There are several on eBay.
Looks like it is the industrial version of a IH 504.
   / Rear lift won't lift #3
I'm just going to start with the obvious, is the fluid filled? When was the 3 point filters & fluid last changed?
DevilDog
DevilDog
The fluid is filled and was changed last summer along with the filter. As far as I know the main fluid reservoir is a shared tank for the tranny/gearbox, 3 point, power steering and FEL. Please correct me if I'm wrong but I think there is only one main filter for the whole hydraulic system.
   / Rear lift won't lift #5
Hello All,
Thanks much.
First of all - is this a new occurrence? Did it work before?
A hydraulic test kit is always handy.
   / Rear lift won't lift #6
Did anyone adjust the flow rate knob. On my mx5100 it is the knob under the seat. Had a grandson twist it closed once and I almost never figured it out!
I've tested it to see if the three point went up & down but never tried to lift anything until now. I think the FEL and the 3 point use the same pump (but I'm not 100% on this) so if the FEL works fine I would think the hydraulics to the back should work. Unless a relief valve is releasing to soon or some other issue.
Don't see any flow rate knobs. Maybe a way to adjust inside the lift unit but I don't think so.
UNUSED GREAT BEAR 1.5CY SELF DUMPING HOPPER (A51248)
UNUSED GREAT BEAR...
City of Buckhannon Onan 450 Set Stand By Generator (A52384)
City of Buckhannon...
2013 Kia Soul Hatchback (A51694)
2013 Kia Soul...
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
50ft Fuel Line (A51573)
50ft Fuel Line...
2010 Ford Escape Hybrid SUV (A51694)
2010 Ford Escape...
