Harbor Freight 20-Ton hydraulic press mods
   / Harbor Freight 20-Ton hydraulic press mods #1
Sodo
Elite Member
Cascade Mtns of WA state
Kubota B-series & Mini Excavator
Simple mods to make a low-cost press work much better.
A handle for the valve made of 1/2" sq steel tubing.
461667d1458542823-harbor-freight-20-ton-hydraulic-img_3951-jpg
Spread it with a screwdriver.
461668d1458542823-harbor-freight-20-ton-hydraulic-img_3951-jpg
Squeeze with vise grip.
461669d1458542823-harbor-freight-20-ton-hydraulic-img_3951-jpg
I make the pump lever semi-permanent by drilling a little hole, for wire.
461670d1458542823-harbor-freight-20-ton-hydraulic-img_3951-jpg
Wheels so I can set it against the wall but move it too. Required a crossbar.
461671d1458542823-harbor-freight-20-ton-hydraulic-img_3951-jpg
4" channel. The crossbar is 1 1/2" sq tube with .065 wall.
461672d1458542823-harbor-freight-20-ton-hydraulic-img_3951-jpg
   / Harbor Freight 20-Ton hydraulic press mods #2
Nice work. If I'm not mistaken, there's a Yahoo group dedicated to that very press.
   / Harbor Freight 20-Ton hydraulic press mods #3
Thanks for the tips. Am looking at that press. Hope to make a press brake for mine to bend sheet metal. will use your T handle as well. Ed
   / Harbor Freight 20-Ton hydraulic press mods #4
Very nice. This is going to be a long and popular thread.
   / Harbor Freight 20-Ton hydraulic press mods #5
Er...nice legs, Sodo!
Terry
Good idea. A press brake would be a great accessory.
Terry stay tuned there will be a lot nicer legs out there than mine. Yah before ya know it there will be LED lighting & sparkly streamers on the jack handle (stolen from granddaughters tricycle) and a shrapnel cage for the press plates. Then comes king of the forum who puts in a 30T jack...... and Shield Arc will have to post a pic of the big press they used on galloping Gertie (a bridge in Tacoma :) )
:shocked:
Its a great tool. Makes me wish I had more to press. A tough little brake for up to 6" wide would be very useful. I've been bending steel in the vise, pounding with a hammer. Ford850 I hope this thread is popular, interested in seeing the ideas!
   / Harbor Freight 20-Ton hydraulic press mods #7
Nice post Sodo appreciate your ideas. One thing I did unfortunately no pics. is glue a plastic strip on either side of the up rites to take the side play out of the arm the jack presses down on.
Billrog taking up that slop has been on my list too but I never thought of plastic. I've been envisioning roller bearings and all sorts of trouble (& bulk that get in the way). Low friction is good.
   / Harbor Freight 20-Ton hydraulic press mods #9
UHMW wear strips.
I use it on gym equipment I build
Terry
   / Harbor Freight 20-Ton hydraulic press mods #10
Soto
I am going to build a heavy break that is the width of the press. I will bend heavy narrow stuff in the middle and wide thin stuff all the way across. Ed
EZ-Go Golf Cart (A51573)
EZ-Go Golf Cart...
2024 JOHN DEERE 461M LOT NUMBER 62 (A53084)
2024 JOHN DEERE...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A53472)
2020 Massey...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
