Tires for Super A
   / Tires for Super A #1
jeffgreef
Plumas County, California
Farmall, Gibson, Windolph, Simar, Bear Cat, Vaughan, Howard
Going to need an 8-24 R1 for my Super A. Like to find a good used, if possible. Freight from the Midwest is more than the tire, so I'll buy one here in California. What's the best way to find one? I could call the IH dealer but I'm sure they'll quote a new price, probably not the lowest. Any advice on the best way to find tires would be appreciated.
Edit- called around, and East Bay Tire here in San Francisco area can get me an 8.3 x 24 new for $179. Seems reasonable.
Is 8.3 OK to use on this? he said the tire will be taller than the 8 I have on the other side. Is that a big deal to have different sized tires?
   / Tires for Super A #2
The difference shouldn't be a problem....is the other tire the original? BobG in VA
   / Tires for Super A #3
For that price, I'd be tempted to just buy a match set.
   / Tires for Super A
No, but the tire I'm replacing might be. Didn't write down the brand.
I wasn't expecting such a low price- I thought tires were a lot more than that- but these are pretty small.
   / Tires for Super A #5
You know, thinking about it...I'm guessing the tires/rims on your SA are originally from a Cub....the standard size for the SA should be 10-11.2 x 24, not 8 x 24...anyone with a Cub confirm this??/ Bobg in VA
   / Tires for Super A #6
Les Schwab can get whatever tire you need for your tractor.
Never had to replace rubber on my 1951 Super A, but I did so on several other old tractors I owned including the right front on my 1949 JD B.
Good luck.
   / Tires for Super A #7
I ALSO would replace both of them to a bigger size, as A's should have bigger size tires then that 8.1's...
They easily have enough power for bigger tires and it makes a lot better tractor out of them!
Don't forget to get new tubes too...
SR
   / Tires for Super A
Hmmm... Interesting... My manual, which is for an A not an SA, says 8-24 for the rears. And that's what's on the tractor. I don't know, I'm just the guy that bought it.
   / Tires for Super A #9
I happened to notice the tire size on my BN yesterday,as I was taking a little coffee/smoke break. It is a '47 model, and has the original BF Goodrich tires on it. 9.5-24's.
   / Tires for Super A #10
I have an A, (2) BN's and a 140 (140 is an "up dated" Super A) all of them have tires bigger than 8.1's...
It's YOUR tractor, put on it what ever you want...
SR
FECON SKID STEER QUICK ATTACH HYD MULCHING HEAD (A51406)
FECON SKID STEER...
American G-Model Pump Jack (A53473)
American G-Model...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2023 BOBCAT T62 COMPACT SKID STEER TRACK LOADER (A53473)
2023 BOBCAT T62...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
