New 2016 Kubota ZD Mowers
   / New 2016 Kubota ZD Mowers #41
Just about to pull the trigger on a new 326 or ZD1211. Any opinions on whether I should buy the time tested 326 or the untested 1211?
Anyone compared the 2?
   / New 2016 Kubota ZD Mowers #42
I looked at both but have only sit in the seat of the 326 and 323 so can't say a whole lot Other than I like the comfort of the 1211 seat better. After mowing with it I can say I like the 1211 but I'm sure the 326 people probably like theirs as well.
   / New 2016 Kubota ZD Mowers #43
I'm curious to know how those low profile rear tires (26x12-16) are working. They look slick but is there an advantage?
Well the mower rides way better than my turd cadet so I dont consider my evaluation fair My Neighbor has a Exmark Lazer Z who took it for a spin. He said it was amazingly smooth ride compared to his. We think the seat is a big part of it. He really likes the suspension seat.
On a car low profile tires help increase cornering compliance allowing for increased lateral traction. Not sure if the same applies here but kubota implies the wider stance and low profile tires help side slip on hills which suggest the same physics apply or atleast marketing seems to think so.
   / New 2016 Kubota ZD Mowers #44
In principle yes in applicability I'd be curious to know for certain. I keep kicking the idea of buying a set of the low profile tires and wheels and trying them out
   / New 2016 Kubota ZD Mowers #46
the low profile tires would be cheaper to foam fill
And a rougher ride. Not sure the objective here but mowing comfort is higher on my priorities as I gracefully age. But profile is sporty and cool in my book. Granted I'm tired and typing this in Korea longing to be home soon.
   / New 2016 Kubota ZD Mowers #47
I checked out the new ZD at the dealer the other day. As I suspected it was more of an evolution as opposed to a revolution. New deck is shallower, but supposed to have more lift. No word on if the new style blades are compatible with my 326 yet, so I got to check in later when they have some replacement blades in stock to compare with. Seat is a nice upgrade. Sort of reminds me of the arguments last year about the BX25d vs "The D". Also more of a superficial update.
The lo pro tires are a bit of a concern, how many manufacturers make alternative tires in that size if you arent happy with the TurfMaster style tires from the factory?
Mostly I was interested in the chute blocker they had installed. Its made from quality components (stainless??) but the activation locking mechanism is awful. Just doesnt work right with one hand IMHO. Why have 2 levers? One for activation and the other for locking, it would work better with a single lever?? For $350 I expected a better thought out device.
Pics of blocker
Shared album - scooby�74 - Google Photos
   / New 2016 Kubota ZD Mowers #48
Scooby thanks for the pictures. The dealer did not have one in stock for me to look at when i bought mine. Your right the double lever looks like it could have been simplified. Like a push to release park brake lever. Push on push off. Someone will probably put a small actuator on one. It would be nice to use an old hi low beam switch and moint it on the floor so you wouldn't have to take your hands off the controls. Heck it has 4 control levers on the floor now why not had a button to the mix
I actually like how some john deere Comercial moweres put the deck lift actuator controls on the end of the control levers
   / New 2016 Kubota ZD Mowers #49
This one controls with your foot for about $400, has worked good for me so far. Power chute I believe it's called.
(INOP) JOHN DEERE TS GATOR (A51247)
(INOP) JOHN DEERE...
2011 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A55314)
2011 MACK Tender...
2014 Volkswagen Touareg - Turbo Diesel - AWD - 189,609 miles (A55302)
2014 Volkswagen...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2021 Ford F-150...
2018 KENWORTH T800 DAYCAB (A53843)
2018 KENWORTH T800...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2021 FREIGHTLINER...
