Need equipment suggestions for new property purchase
   / Need equipment suggestions for new property purchase #11
I'd buy a cheap truck first. I bought a Chevy 1500 4x4 for $1500. I'd buy a used tractor next. If you search for the right deal you should be able to get both for your budget.
   / Need equipment suggestions for new property purchase #12
X2
A truck is a must IMHO.
X3. You can probably get a decent used truck and a Sub Compact around 30. Keep in mind implements add up quick lol.
   / Need equipment suggestions for new property purchase #13
You may need one set of equipment for getting it into shape, and a different set for maintaining it from then on. Combine where you can. Rent if you have very different short term needs.
Bruce
   / Need equipment suggestions for new property purchase #14
I'd budget about $5,000 for a decent beater truck , and about $15,000 for a used tractor with a FEL. This leaves room for a nice implement fund and more spending room if needed.
   / Need equipment suggestions for new property purchase #15
I don't see how you're gonna get both with that budget unless you plan to finance.
I will add a caveat to that- If you have mechanical abilities that is...
You can buy a fair amount of good used equipment for that budget. If set on all new equipment -it gets expensive quick
If you are not mechanically inclined, then very, Very careful shopping will be needed buying used equipment and a 4x truck that (possibly) will fit the budget and hopefully not need repairs.
   / Need equipment suggestions for new property purchase #16
Here are some eBay TRACTOR listings near Cary, North Carolina: Industrial Tractor | eBay
There is more used equipment available in the Fall/Winter than in Spring/Summer.
   / Need equipment suggestions for new property purchase #17
   / Need equipment suggestions for new property purchase #18
For the budget several on that ebay listing are 6-7K and that would work - here's a BX24 that is very nice for $15K leaving 10-15K for a truck which is what others suggest - get both used and the budget will work.
ku-bx24/loader/backhoe
Thank you for the feedback everyone! I have a lot to think about. I'm going back to Kubota and JD to test drive a few tractors this week, and also scout some used trucks and on eBay
   / Need equipment suggestions for new property purchase #20
You might want to try shopping some other brands if you're on a budget. JD tends to be expensive and you pay a lot for their label and Kubota isn't that far behind.
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
2006 Mercedes-Benz (A55758)
2006 Mercedes-Benz...
2000 FORD F-350 SUPER DUTY (A58214)
2000 FORD F-350...
2019 Ford F-550 Altec AT41S 40ft. Bucket Truck (A55973)
2019 Ford F-550...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
2018 VOLVO VNL TANDEM AXLE SLEEPER (A58018)
2018 VOLVO VNL...
