Need equipment suggestions for new property purchase
   / Need equipment suggestions for new property purchase #11
I'd buy a cheap truck first. I bought a Chevy 1500 4x4 for $1500. I'd buy a used tractor next. If you search for the right deal you should be able to get both for your budget.
   / Need equipment suggestions for new property purchase #12
X2
A truck is a must IMHO.
X3. You can probably get a decent used truck and a Sub Compact around 30. Keep in mind implements add up quick lol.
   / Need equipment suggestions for new property purchase #13
You may need one set of equipment for getting it into shape, and a different set for maintaining it from then on. Combine where you can. Rent if you have very different short term needs.
Bruce
   / Need equipment suggestions for new property purchase #14
I'd budget about $5,000 for a decent beater truck , and about $15,000 for a used tractor with a FEL. This leaves room for a nice implement fund and more spending room if needed.
   / Need equipment suggestions for new property purchase #15
I don't see how you're gonna get both with that budget unless you plan to finance.
I will add a caveat to that- If you have mechanical abilities that is...
You can buy a fair amount of good used equipment for that budget. If set on all new equipment -it gets expensive quick
If you are not mechanically inclined, then very, Very careful shopping will be needed buying used equipment and a 4x truck that (possibly) will fit the budget and hopefully not need repairs.
   / Need equipment suggestions for new property purchase #16
Here are some eBay TRACTOR listings near Cary, North Carolina: Industrial Tractor | eBay
There is more used equipment available in the Fall/Winter than in Spring/Summer.
   / Need equipment suggestions for new property purchase #17
   / Need equipment suggestions for new property purchase #18
For the budget several on that ebay listing are 6-7K and that would work - here's a BX24 that is very nice for $15K leaving 10-15K for a truck which is what others suggest - get both used and the budget will work.
ku-bx24/loader/backhoe
Thank you for the feedback everyone! I have a lot to think about. I'm going back to Kubota and JD to test drive a few tractors this week, and also scout some used trucks and on eBay
   / Need equipment suggestions for new property purchase #20
You might want to try shopping some other brands if you're on a budget. JD tends to be expensive and you pay a lot for their label and Kubota isn't that far behind.
2007 Ford E-350 Passenger Van (A55973)
2007 Ford E-350...
30pc 3ft. x 8ft. Red Polycarbonate panels (A55758)
30pc 3ft. x 8ft...
2026 Quality Steel Dump Trailer (A56858)
2026 Quality Steel...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
2005 Chevrolet Impala Sedan (A56859)
2005 Chevrolet...
16ft T/A Flatbed Trailer (A55758)
16ft T/A Flatbed...
