It has been decided and it is the PX9020PC
   / It has been decided and it is the PX9020PC
Oh , respect them very much but boy with AC and power it is so much easier. IT makes it even more impressive that they do it the old fashioned way. I know my father in law started off with a very small metal wheeled tractor out on the farm and now his son is still farming with the big Case stuff. This is my first foray into small tractors.
   / It has been decided and it is the PX9020PC #62
Calling a 90hp tractor small makes one think twice, but in comparison to the really big ones I get it.
Looking forward to pictures of your future endeavors.
True but the last tractor I drove was a 380 HP Magnum Case IH with duals on all the tires but had no loader for that one but it did have a GPS directed draw bar.
It is what we use for utility tractors on the big farm but it is going to be my main goto do everything tractor.
   / It has been decided and it is the PX9020PC #66
"chore tractor". 90hp is a small tractor.
Good to see you got'er home! Good luck with it. Check the bolts'nuts'nstuff....
I think you are going to like it! Congrats!
Already found one loose one so will have to go over it next trip down.
   / It has been decided and it is the PX9020PC #68
What is that you're pulling? I haven't seen it before.
It is a spring tooth harrow. The depth is adjustable by moving the wheels up/down to desired depth. Behind that is just old rod iron railing to smooth out everything for seeding.
Here's a little better picture.
Hooked up the woods 15 foot batwing. bW180 today for the first time. Wow that PTO shaft is heavy but it all connected well. I had to remove a spacer to get the proper cut height I wanted but boy that cutter and the PX are happy together. I did one field I 40 mins that took two hours plus on the ZTR mower. Tomorrow is the big field that used to take 8 hours plus in low grass and 2 -3 days in the heavy stuff. Then put on the box blade and pull downed branches and junk from the woods. Got a home pile of old metal already that the previous owner just dumped there. He was a contractor and would dump lots of stuff in the woods
   / It has been decided and it is the PX9020PC #70
If you were to shoot some video, I'd watch it ;-)
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56129)
2017 FREIGHTLINER...
(4) CAMARO 5 LUG WHEELS & 245/50R16 97H TIRES (A54757)
(4) CAMARO 5 LUG...
Dump Truck Box with Tarp System (A51691)
Dump Truck Box...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
2018 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2018 ALLMAND BROS...
TRANSMISSION JACK & TRACTOR CYLINDER (A54757)
TRANSMISSION JACK...
