GC break in period
   / GC break in period #1
fxdb96
SEBAGO
Massey Ferguson
Owners manual states to run it at full throttle for the first 50 hours. Have you all broken in your Masseys like this? IMG_20160316_175510361.jpg
Huh? You sure there isn't a NOT in there? Bought mine used but that would the first anything new that I have heard of that wants you to break it in like that.
Operate at full speed. Prevent excessive load... If engine speed decreases too far operate in lower gear to keep higher engine speed.
   / GC break in period #4
I have operated mine at full throttle, since I got it.
The only exceptions are, warm up, and cool down.
   / GC break in period #5
running a new engine at full rpm without a load on it prevents the rings from fully seating, I think that's why most lincoln dealers will load bank a new diesel welding machine before the customer takes delivery. I know the cummins warranty info suggests heavy towing for the first 10,000 kilometers (6000 miles)
I usually run mine at lower rpm unless it starts lugging. there is a spot somewhere between 1500-1700 where the engine seems to run smoother. i can tell because the rattles seem to quiet down... not that they are very bad, but it seems to me that a quiet machine is a happy machine. :)
if i'm pulling a snow plow or heavy work and the going gets tough, then it's full throttle.
I usually run mine at about 1700 rpm unless it starts lugging. if i'm pulling a snow plow or heavy work and the going gets tough, then it's full throttle.
Agreed... My thoughts as well.
   / GC break in period #7
In my opinion, you breakin a new engine the same way you breakin a new employee.
Vary the speed and difficulty of work because that is how the future work will be.
Make sure they are not overheated nor allowed to just "plug along" because neither is real lufe desired.
Make sure their needs are properly maintained during the breakin period with breaks to check and verify their needs are properly being maintained.. in either case . . . just pay attention because neither comes with an "auto pilot" button :)
People and engines are different in countless ways . . but they are similar in many ways when it comes to the new and breakin process. Treat them too harshly and it gets expensive when they become unavailable for service. Treat them too gently and that becomes the future expectation and then they break when reality comes-a-callin'.
Both machines and people benefit from a positive balance from their operator :)
Get paid on time - check oil on time.
Have some form of benefits to keep them going - change the fluids a bit earlier than required
Value their accomplishments - use clean, quality fuels, fluids and lubricants.
Have a casual party or acknowledgement once in awhile - use grease regularly and check fastener tightness
Less yelling and more leadership - don't over rev the engine or spin the wheels often.
Challenge their abilities - try new ways to use the tractor
Find compatible people to build success - search for implements that fit the size of the tractor WELL, not just OK.
Employees - tractors. In each case if you pay attention to them . . they'll work for you a long and successful time. Abuse them or coddle them and your investment diminishes. In both cases, what you pay to get them is less important than what you do to properly maintain them :)
2007 Ford Focus Hatchback (A55853)
2007 Ford Focus...
2019 Taylor Trailers 7 Ton T/A Flatbed Utility Trailer (A55852)
2019 Taylor...
2014 International Maxxforce DT (A53317)
2014 International...
Faza F300 3pt Fertilizer Spreader (A56469)
Faza F300 3pt...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2015 Toyota Highlander XLE SUV (A56859)
2015 Toyota...
