Alternator is overcharging, need to rebuild it!!!
   / Alternator is overcharging, need to rebuild it!!! #1
alia176
Tijeras, NM
Mahindra 3316HST
Hey fellas,
My ALT is way overcharging the battery at nearly 15vdc! :eek: That explains the copious amount of corrosion on the terminals and on the hold down bar. In any case, I can easily rebuild it myself and need to buy a rebuild kit. Well wait a min, is it still under the 5 year warranty? Doesn't really matter a whole bunch but that thought just popped into my head.
Has anyone suggest a vendor for purchasing a rebuild kit? My tractor has 85 hours on it so it's still a young buck :D I suppose I can't just leave well enough alone and may even go for a higher output unit as there seems to be plenty of room in there. It's a 50 amp unit and I prefer to upsize the case for more output vs simply modifying the existing case for more output. Keeping these things cool is very important as you know. Anyone done this to these alternators? I'd imagine we all have similar size engines so the available space should be similar as well.
Thank you.
   / Alternator is overcharging, need to rebuild it!!! #2
Maybe it it just the voltage regulator. Isn't that a part replacement on an alternator?
   / Alternator is overcharging, need to rebuild it!!! #3
What is the actual voltage. You say nearly 15v, so to me, that means 14.6-14.8v.
Is that idle or reved up?
Sounds normal to me. What voltage you looking for?
   / Alternator is overcharging, need to rebuild it!!! #4
It sounds normal to me. I haven't ever checked my tractor alternator, but my truck produces about 14.5 volts idling.
14.9 volts at idle and 1500.
   / Alternator is overcharging, need to rebuild it!!! #6
Yep output voltage is a function of the regulator not the rest of the alternator. If it was 14 something at RPM, that's normal and it's supposed to be that way. How accurate is your meter and are the batteries in it good? Some meters are so far out of calibration it's pitiful and some aren't worth a hoot right out of the box.
   / Alternator is overcharging, need to rebuild it!!! #7
Normal.
   / Alternator is overcharging, need to rebuild it!!! #8
Also note that a bad battery can cause the charging voltage to be elevated.
My truck charging voltage is about 15 volts. Both on the truck's voltmeter and on my nice quality digital volt meter. It has read that for 5 years. Batteries seem to doing just fine,.
   / Alternator is overcharging, need to rebuild it!!! #9
Didn't you believe those who posted in the earlier thread you made?
   / Alternator is overcharging, need to rebuild it!!! #10
There was another thread about this huh?
   / Alternator is overcharging, need to rebuild it!!! #12
Mine charges at around 13.9 at idle and 14.8 when throttled up.
After I read your post I was puzzled and found that I hit submit twice somehow! I'm unsure how to delete my other thread or this maybe an admin thing only.;
In any case, it sounds like my ALT is doing fine, just need to clean up the crud and spray the battery post with terminal protector. I do have those green and red anti-corrosion pads but they are not able to keep up with the rate of corrosion.
As someone stated already, the Mahindra batteries are notorious for this kind of buildup.
Thanks for the feedback fellas.
   / Alternator is overcharging, need to rebuild it!!! #14
Clean with baking soda....and seal all connections....That will slow all corrosion down...
   / Alternator is overcharging, need to rebuild it!!! #15
   / Alternator is overcharging, need to rebuild it!!! #16
Baking soda will clean the corrosion but you must not get any in the battery , a kettle of plain boiling water will also clean the post right up.
When mine goes, I'll replace it with one of these
Heavy Duty/Commercial Specifications – ODYSSEY battery
keep a maintenance charger on it when stored and not worry about it anymore. It'll cost like the dickens but it's worth it.
Those are nice batteries and I have some experience with them. However, batteries are consumable items to me so for some time now, I've been purchasing blem Interstate batteries for $45 (deep cycle, normal cycle, etc) at my local Interstate supplier. Everything from my rock crawler to the DD, they all sport the blems. However, I'll try to find a battery that fits in the same space but taller for more CCA and reserve capacity in preparation for a 5k winch installation.
Thanks for the feedback.
   / Alternator is overcharging, need to rebuild it!!! #18
I agree with the baking soda in warm water to clean up all the corrosion.Been doing this for years.I also coat my terminals with either grease or silicone dieletric compound.As far as the corrosion all over the holdown and all are you sure its not from the batteries vent area rather than the terminals that is causing it
   / Alternator is overcharging, need to rebuild it!!! #19
If you want more power in the same space then an AGM is your answer. They offer more charge density and more cranking performance than wet cells especially at cold temps, about twice per unit volume I think.
I've found that the Odyssey design offers more power for volume than the Optima design as the Optimas are spiral wound so wastes a lot of volume for nothing but air. Optima has started having a lot of problems lately, it seems they've started selling their label instead of batteries. At least many of my wheeling buddies have been complaining about them for a few years now.
I use a couple of Odysseys in my rockcrawler which includes heavy winching duties along with some welding too. Nothing sucks current like a fully loaded winch. My 8K winch typically hits its heat limit before the little PCL 1200 battery finishes dishing the power out, although it's usually helped out with a 100A+ alternator.
I don't mind spending a little extra money so I don't wind up stranded way out in the boondocks somewhere cause AAA ain't comin.
So far they've been holding up very well so they haven't been consumable for me. I'd rather buy something once rather than two or three times. I think over time you'll likely end up spending about the same money either way. In one lump or in several lumps, take your pick.
Another advantage of the AGMs is higher tolerance to vibration and shock not to mention being spill proof. You can install and forget them but you do have to at least keep them maintained with a charger like any other battery. No battery no matter how much you pay for it will tolerate abuse or neglect and live.
No messin with topping up and all that nonsense though since they're all hydrogen recombinant and sealed up tight so no corrosion problems either.
But hey, if the US Army is putting them in M1 Abrams tanks, then they are good enough for me and my stuff.
Note: Odyssey was previously the automotive end of Hawker Energy.
ODYSSEY battery - Design Advantages
Great points and I can appreciate info from a retired EE. We both have Yota crawlers and are both EEs, what a coinkydink!! :) I've gone through Odyssey and DH Platinum in the past for my winching and welding duties and now settled on blems. Admittedly, I'm not too abusive on my batts on the Landcruiser like you I'm sure. Still, running a Warn M10k winch on a 7k pig does manage to strain the charging system, on rare occasion.
Thanks for the inputs, very valuable.
5' ROTARY MOWER (A60430)
5' ROTARY MOWER...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
CATERPILLAR CS54B SMOOTH DRUM ROLLER (A60429)
CATERPILLAR CS54B...
2014 MASSEY FERGUSON 5612 DYNA-4 TRACTOR (A59823)
2014 MASSEY...
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
