5030
Epic Contributor
- Joined
- Feb 21, 2003
- Messages
- 26,999
- Location
- SE Michigan in the middle of nowhere
- Tractor
- Kubota M9000 HDCC3 M9000 HDC
Thanks for the 411.... that does make more sense that the complex vanes are on the cold side. I'd heard of issues with variable vanes not being exercised enough, for some reason that had me thinking of the hot side....
I don't know those small Ford automatics well..... given any choice at all (tougher today), I pick stick when I can. Ford isn't the only one with issues in autos, though some of that IMO is from Ignored for Life ATF....
I believe you, but it is "interesting" that a modern engine can run that badly and not throw a code..... but then again that would be like the OEM admitting to a problem....
If you could do it without the data going anywhere, it would be pretty interesting to get your Transit on an Exhaust Gas Analyzer.
I'd find it pretty ironic if many of these "clean" modern GDI engines are running around spewing tons of emissions..... esp. after Vdub getting their head kicked in for "dirty" diesels.....
Good weather should be here soon, pls let us know how the Transit service goes....
Rgds, D.
The siamesed twin 3 speed trans in the Focus and Escape is actually 2 stick shift boxes with a common mainshaft and an electronically actuated twin plate clutch and gear change servo. I don't use ATF, it takes synthetic gear oil. The electronic clutch gets wonky after a while and shudders. Lots of You-Tube vids about it and how to 'cure' it. My take was just get a stick and a manual clutch (5 speed) which I did and eliminated the electronic portion. Cars today already have too much electronics.
It was designed so aunt minnie could drive it like a conventional automatic but when Minnie felt 'sporty', she could manually shift the box. Personally, I think it's a bad idea but it is simpler than a pressure actuated full auto with a torque convertor and there is no parasitic loss either, plus it weighs much less.
I would have preferred the 6 speed stick but thats only available in the 230 horse turbo charged Focus ST. My 150 is plenty for a roller skate with 4 doors.
