Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #3,201
Bottom ends burn up if you run 50:1 on a ported saw - it's too little lube. I've switched to the heavier ratio in all my saws. More oil never scored a cylinder or stuck a ring. ;)
   / Tractors and wood! Show your pics #3,202
I have a hard time believing any Stihl user was running 32:1. Stihls have not used that ratio in any motor for 3 decades at least.
Just because the manual says 50:1 doesn't mean that's what people run. I know lots of guys run 32:1. I generally run 40:1. A bottle of oil that makes 2.5 gallons of mix gas at 50:1 makes 2 gallons of 40:1.
   / Tractors and wood! Show your pics #3,203
For what reason? If the engine was designed at 50:1 you are changing characteristics by putting something else in it and taking it away from its design optimum.
   / Tractors and wood! Show your pics #3,204
The reason, as Jim stated, is for extra lubrication. You're right you change the characteristics. It has the effect of leaning out the mixture that gets burned. This is easy to compensate for since there are adjustments on most saws to dial in the fuel/air mixture.
   / Tractors and wood! Show your pics #3,205
The guys on the chainsaw forums think they know more than the manufacturers. They think they are extending the life of their saw. Most guys on the saw forums run 32:1.
   / Tractors and wood! Show your pics #3,206
I might consider 40:1, but 32:1 is ridiculous. I'm not a fan of a trail of blue smoke coming out of my equipment. I suppose I should add extra oil to modern diesel fuel too.
   / Tractors and wood! Show your pics #3,207
You might want to do that instead of replacing injectors. Just say'n... ;)
In order to run 32:1, you need to jailbreak the EPA limiting caps put on every new saws carb adjustment screws. When delivered from the factory, they're set so lean they'll make the emissions lifespan (indicated in hours, found on the saw's package: some are 125 for consumer saws and pro saws are usually over 300) but not much life left after that. Or you can remove the limiters and richen it up and enjoy minimal wear for the decades you're used to getting out of saws going back to the '70's.
Oil technology has improved in the last 5-6 years, but fuel quality continues to go to crap. I run 91 octane non-ethanol because I can't buy 87 octane non-oxy in my area thanks to the stupid ethanol lobby in MN. Go to South Dakota and they have 87 non-oxy and it's even 10 cents cheaper than the adulterated 87 octane garbage in the pump next to it. Go figure! Running your saw too lean will burn it up. Running more oil than 50:1 actually reduces the octane rating, so you need to fatten up the mix to keep it from pinging. When I pull a jug, there's a nice film on everything in the case since switching to the 32:1/91 non-oxy. When I was running 50:1 or even 40:1 and 87 ethanol crap, there was never any signs of oil in the case. It felt dry!
So, do whatever you want with your saws. Open one up sometime after you've been running it and see what's in the case. Main bearings need oil.
My saws don't smoke, and I use a tach to set them.
   / Tractors and wood! Show your pics #3,208
I think a common mistake when mixing oil is to think the ratio is based on the equipment, but in reality it's based on the oil. A modern synthetic at 50:1 is lubricating as good or better than older dino at 32:1. That's why we can run older equipment with a 50:1 synthetic mix and it ain't going to skip a beat or burn up, even though when the owner's manual was written, 32:1 oil was the state of the art. With 50:1 synthetic, it's getting as good or better lubrication than it did in the old days at 32:1.
If you're taking a 50:1 spec oil and mixing it to 40:1 or 32:1, it's just a waste. If someone really wants to run 40:1 or 32:1, look for a low tech dino oil that calls to be mixed to those ratios. I don't see the point, of course.
   / Tractors and wood! Show your pics #3,209
Look at the Euro spec on a Husky 80cc+ saw and you'll find it's not told to be using 50:1 like they do here. 32:1 is being safe. Safe is cheaper than a new slug and jug.
   / Tractors and wood! Show your pics #3,210
Stihl already offers FI on their cutoff saws. I recently bought a new MS661 and the
dealer and I were talking about FI he said Stihl will be offering it with the next 2 years.
If one is a logger who puts many hours on a saw on a daily basis, I can see having the latest-and-greatest. But
even THOSE guys could buy an older saw, and fix it indefinitely. All the wear items for an MS440, MS660, 3120,
or 372XP, etc. will be available for decades to come, and full refurbishment costs substantially less than
a new saw at that level.
If FI means more "drivability", as it does with autos, I am for it. It would run cleaner, too, but there is a definite
maintenance price to be paid.
2011 ELITE TRAILER 20 T/A GOOSENECK (A55745)
2011 ELITE TRAILER...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
1987 Ford F800 E-One Pumper Fire Truck (A55852)
1987 Ford F800...
2009 CAT 140M MOTOR GRADER (A55745)
2009 CAT 140M...
