muddstopper
You need a 3-port valve as others have stated, SODO. Ideally on the valve stack. To provide
work-port relief inline, you need something like this, a "crossover" RV. An RV must dump
to a low-pressure line to the tank.
I had these made up for my hydraulic chainsaw projects, which needed to be limited to
2000 psi. Definitely less than $100, but you have to find a place to mount them. This
is about as small as you are going to get with an inline setup.
Im missing something here, it looks like all your lines are tee'd together.
