How fast does a big tractor go?
   / How fast does a big tractor go? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
By big I mean probably 80HP plus.
Background - We were driving along RT24 in Alabama which is finishing construction. We were doing about 50mph along with the rest of traffic. In a steady stream of oncoming traffic (going about the same speed) came a big tractor doing about 50. I had difficulty seeing it because the sun angle was low and I was contending with traffic.
It almost looked like it might be a construction dedicated tractor single seat, no side-by-side.
I've seen tractors in Europe routinely going at fairly high speed, but not many around here (northeast Mississippi).
So how fast does your big tractor go?
   / How fast does a big tractor go? #2
My 100hp does around 25mph, the big 8 wheel tractors I have drove will do 37mph down hill on highway.
   / How fast does a big tractor go? #3
You happen to at least get a make of the machine?
Most do 20-25. Very few get into the 30's
   / How fast does a big tractor go? #4
My loader tractor will go 22mph, my distant neighbor has several tractors they haul chit with, they go 33mph...
SR
   / How fast does a big tractor go? #5
Same here, 8th gear in my nh 7610s @ ~95hp will make 25 near pto rpm.
Which is about right since a SMV plaque is good for 26mph
   / How fast does a big tractor go? #6
I'm sure it's different on a bigger tractor, especially with a cab, but 17 feels plenty fast on my Kubota.
My 8N with a Sherman over-under was rated to do 23 in 4 hi at wot according to the sales literature. That would be absolutely terrifying!!
   / How fast does a big tractor go? #7
My neighbors big 550hp Versatile shows a max speed of 30mph on the speedometer. He will never go that fast because when he's out on these country roads - going from field to field - he always has some form of implement attached and he is usually almost as wide as the entire paved surface.
   / How fast does a big tractor go? #8
I can verify that they really do that.
Makes it nice hauling wood in the trailer from down the road a ways. Just gotta make sure the steering linkages and radius rods are well cared for and tight.
   / How fast does a big tractor go? #10
Well my LS isn't 80+ HP but rated at 70 and it will do 25 in high gear which is plenty fast enough for me. It does handle very well at top speed though.
PS I have had it at 75 MPH but it was loaded on a trailer hooked behind my Chevy truck.
2007 FORD F150 XL TRUCK (A51406)
2007 FORD F150 XL...
1997 CMC S102 END DUMP TRAILER (A53843)
1997 CMC S102 END...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55218)
Kubota SVL65-2...
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
2005 International 4300 Telsta Telescopic Bucket Truck (A52377)
2005 International...
1983 Case 580D (A47477)
1983 Case 580D...
