How fast does a big tractor go?
   / How fast does a big tractor go? #11
But tractors aren't usually set up with much caster to provide directional stability at any speed. They usually have near-zero caster to make turning the front wheels easier on soft surfaces (dirt). Getting mine much over 15-20 makes me nervous. A little too twitchy.
   / How fast does a big tractor go? #12
Farm tractors are changing, a lot of the manufacturers are now adopting to go with the European design, with IVT transmissions, resulting in higher road speeds. In Europe, the cost of ownership of a farm having a bigger type truck, or tractor trailer unit are almost cost prohibitive with licensing, taxes, etc, so the tractor manufacturers have adapted the tractor to travel at near road speed, not only to improve turn-around times from field to farm, but to also help with traffic flow. Some of the JCB's ( fast-tracs) and Fendts etc have road speeds of 40 plus MPH. A lot of these tractors also have a front suspension system to help cope with the road surfaces. This is slowly transferring to North American models as well. I guess the biggest limitation would be in tire design, to build a tire that can handle the road and field surfaces, as well as the speed and the heat generated.
Cheers
Roger
   / How fast does a big tractor go? #13
My neighbor has a Fastrac that will go over 40 mph. I don't know which model he has though.
Agricultural Tractors
   / How fast does a big tractor go? #14
JCB Fastracs fly insofar as tractors go.
   / How fast does a big tractor go? #15
Freekin krauts truly crave speed don't they?
   / How fast does a big tractor go? #17
You get up around 18 mph or so on an big old open station tractor with a little loosy goosy steering [ bouncing up and down thru the total range of your seat ], and that is plumb fast enough..... :)
   / How fast does a big tractor go? #18
Europen depending has 50 and 60KM/hr tractor speed limits . Thier tractor trailers really do have "tractors" pulling them.
   / How fast does a big tractor go? #19
If I'm not mistaken on many they have a highway gear option that is special order.
Same as creeper gear for snow blowing or tilling.
A friend used to drive 30-40 miles in all directions to collect hay and for sure they were moving at 40 or more, it was a ford.
   / How fast does a big tractor go? #20
Cheers
Roger
My brother writes for several ag publications (free-lancer) and gets invited to a lot of machinery events...he said the primary goal in the industry now is "road speed". Figure with huge fields and expensive equipment, makes sense to be able to move quickly from one field to the next.
200387 (A51247)
200387 (A51247)
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
2018 Ford Fusion Hybird (A53424)
2018 Ford Fusion...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55301)
UNVERFERTH 330 8...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
