Geothermal Desuperheater for DWH plumbing
   / Geothermal Desuperheater for DWH plumbing
My system is also setup like you want and I don't think there is anyway it would ever get to hot in the first tank. I've never checked my temp but I don't think it ever gets hotter than maybe 100 degrees F.
Does your setup have an internal pump? Or an external one that you have to furnish (or the installer had to furnish)?
   / Geothermal Desuperheater for DWH plumbing #12
I have a new 7 series water furnace HP and it has is own pump built in for my water heater. It's a small switch located by the pipe feeding my water heater.
All the other brands I see seem to have an internal pump and temp control. Not the geocool.
   / Geothermal Desuperheater for DWH plumbing #14
Mine has a circulator pump.
   / Geothermal Desuperheater for DWH plumbing #15
I assume it's an internal pump but I have no idea, we just wrote the check.
   / Geothermal Desuperheater for DWH plumbing #17
Yes, came with the unit.
   / Geothermal Desuperheater for DWH plumbing #18
Recently upgraded my older climate master unit to a newer model. Both have internal pumps for the ground loops and the hot water generator. Old unit was eer 15 and newer unit is eer 22.
Got a reply about all this from the place I purchased. Which was Ingram's out of KY.
They suggest a grundfos up15-18 pump to circulate DHW through the DSH.
Said something to the effect that the head temp of the refrigerant will never exceed 130, so there is no risk of overheating.
I'm no HVAC expert so I don't know what the temps of R410a run. But assuming this is true, I can see how in loser demand conditions, like low stage with lower refrigerant temps, and a tank of water already at 125 degrees, that the DSH very well can have a reverse effect and actually cool the DHW.
Thus i like the idea of the temp controls and how the bard works to prevent this. And not waste energy running the DSH pump when no benefit or a negative benefit will result.
So, I ordered the bard.
   / Geothermal Desuperheater for DWH plumbing #20
When we ordered our GEO unit I was expecting a second circuit for domestic hot water which would be generated whenever the unit ran but I wound up with the desuperheater as well. I plumbed in the tanks like yours but found the unit seldom ran long and hard enough to generate much hot water. Then we cut back on the wood we were burning in the fireplace and started to heat 40 gallons each night. We are on time of use billing so I connected a time clock to the elements so they only run during cheap (.21/kwh) hydro hours.
If the cold water line feeding the geo unit gets above 120F the pump turns off on ours...
2021 Delta Redirective Crash Cushion 75000 (A48081)
2021 Delta...
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
2013 CHEVROLET SILVERADO 2500HD (A50854)
2013 CHEVROLET...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A48081)
2015 Ford F-550...
2004 Ditch Witch RT70M Ride On Trencher (A50860)
2004 Ditch Witch...
2015 Ford F-450 Bucket Truck (A50860)
2015 Ford F-450...
